![]() Drives: 2013 Camaro SS, 2012 Impala LT Join Date: Aug 2023
3 to 4k budget what would you do?
Hello, I am the owner of a 2013 Camaro SS. It is an L99 6 speed auto with just exhaust and tune done currently. I want to get deep into the 12's in the quarter mile. My question is, are there any modifications that are a must to get there? I know some cars its gears or drag radials, it is not always hp mods but those are ok too. So if you had a 3k to 4k budget what would you do to maximize it for faster quarter mile times.
![]() Drives: 2013 ZL1 Join Date: Sep 2021
Suspension and tires would be my first priority.
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
Cam, heads, headers, torque converter, gears. Probably well up over your budget already not to mention tires and some suspension improvements. What does your car currently run in the 1/4? You might be able to put some 3.91s out back and get some pretty good results.
Tri-County Camaro SWFL
Drives: 2013 IOM 2SS/RS/1LE Join Date: Apr 2013
FBO with rear gears and suspension. Intake, headers, rod mod manifold, 3:91 gears, trailing arms, toe links and solid subframe bushings.
My 2011 SS/RS L99 with just a CAI, resonator delete, axle back exhaust, ported TB and 315/35/20 rear tires and stock gear ran a 13.01, forgot what the mph was. Did a set of LT's and a custom dyno tune on the engine and trans and got it to do 12.68, again not sure what the mph was. Oh, and stock converter as well.. And I did that for under 1700 bucks, but that was back in 2012... Now the prices have almost doubled on performance parts.
#6 |
GPI Sales Consultant
Drives: 2011 Camaro 2SS SGM Join Date: Jul 2016
Headers, converter, 17" rear wheels with drag radials, and a tune would be about the best ET you could buy within your budget.
Got a question about a GPI product? Feel free to shoot me a message! |
#7 |
Sucker Punch
Drives: 2013 Black ZL1, 2022 Silverado ZR2 Join Date: Jul 2014
This would be a good start, if you can afford it, a cam and lifters will really add some power to it. but it would be outside your budget.
427 Dart SHP Pro LS Block, Callies Magnum Crank, Callies Ultra I Beam Rods, Diamond Pistons, AGP twin Turbos 6865, Mast heads, Cam Motion LLR cam, Morel tie bar lifters, Crower roller rockers, NW 103MM TB, ID2600 XDS, Fore Triple, DSX, E85, ARH Turbo Headers, Corsa, Jakes stage 5 4L80, Circle D, RPM Roll Bar, BMR, Carlyle Racing 15" conversion kit.
#8 |
Wow thanks for all the responses. It is a lot to consider. I do want to add one detail I left out. The car as it sits has huge wheels someone before me put 285/25/R22 they grip pretty well, but I imagine that big of a rim is hurting acceleration. I am leaning towards drag radials, smaller rims and gears.
Metal and muscle cars. |
#9 |
#10 |
What ratio gears are good for these cars? Its a street/strip car so I don't want to be at 3,000 rpm at 70 for sure. I had 4.10's in a truck I drag raced and it was a nice compromise but not sure on a Camaro. Its a 6 speed auto.
#11 | |
https://gwatneyperformance.com/geari...utomatic-cars/ If you're serious about running form a standing start then you're right, those 22" wheels are not doing you any favors in traction, and I'd be willing to bet they are super heavy as well.
#12 | |
Give speed a chance
#13 |
#14 |
In terms of performance value, the converter is worth more than the gears in terms of maximizing the ET potential. Both very much matter, but if I was on a budget and had to choose only one then the converter would be the move. If you're doing the work yourself, it's also arguably an easier install.
| Tags |
| l99, performance, quarter mile |
