Old 08-27-2025, 09:39 PM   #1
Birdseed
Drives: 2015 Camaro SS 6AT/L99
Please Help me solve this issue
First off I would like to start with I appreciate any and all answers.
I have had a cylinder #2 mis-fire for a little while, I replaced the Coil-Pack, spark plug, and spark plug wire. Still missing heavy at idle and under throttle, so I noticed the plug was white when I pulled it which typically means it was running lean. I moved the injector to another cylinder just to verify that was the issue and it followed. So I replaced the Injector with a AC DELCO/OEM Equivalent Part number 0280158051 which is the same part # as the OEM injector that I pulled which is rated for 42LB, I installed the new one, same issue, so I moved that specific injector to cylinder #1 and the miss-fire moved to that cylinder just like the stock one had done previously. Am I missing anything? The only difference I can find between the two new Injectors and the old one, is that the 4 Holes pictured below is smaller on the AC Delco/Bosch compared to the factory one is that the AC Delco/Bosch have a 3 digit code [927] stamped on them where as the oem has [060] I also Purchased the Bosch oem equivalent injector just to make sure the issue was not just with AC Delco. The are all rated for the same flow rate, so I am honestly puzzled. I mean the misfire follows to whichever cylinder it is placed so I am positive that is the issue.
Everything I have read online states that both injectors are plug and play.
Birdseed is offline   Reply With Quote
Old 08-28-2025, 05:40 PM   #2
bsn
Drives: 2013 ZL1
Are you buying them off Ebay or Amazon?
bsn is offline   Reply With Quote
Old 08-29-2025, 12:27 AM   #3
Birdseed
No sir, one came from Autozone, The other Oreilly's
Old 08-29-2025, 08:39 AM   #4
gtstorey
I don't know what the history of this car is, but the number on the "OEM" is not a stock GM number so who knows what is actually on the car. Maybe they are fake/counterfeit injectors and someone tweaked the tune to make them work.
And there is more to injector data than just flow rate. When does the misfire show up?
Old 08-29-2025, 11:03 AM   #5
b4wheeler
b4wheeler's Avatar
Drives: 2011 Camaro 2SS Vert
This is your factory AC Delco PN# 217-2425
2011 2SS/RS Convertible, Victory Red, Roto-Fab CAI, Stainless Power 1 7/8 headers, No Cats, Straight piped, Bo White TB, Circle D, 3.91, ZL1 CONVERSION, CDC Roll bar and some powder coating and dipping.
b4wheeler is offline   Reply With Quote
Old 08-29-2025, 01:20 PM   #6
Birdseed
That is very true. I checked the tune with my brothers HP Tuner setup and everything is factory nothing has been touched tune wise, so I'm thinking what I thought was factory Injectors must have been replaced with some kind of knock off variant. The misfire is across the Entire rpm range, but just on that cylinder.
Thinking I am best off just replacing all 8 Injectors at this point.
Old 08-29-2025, 06:31 PM   #7
Thraul Returns
Drives: 2013 zl1
Hey man looks like what they sold you isn't correct. Call a Chevy dealer and give them your vin, they'll sort you out.
Thraul Returns is offline   Reply With Quote
Old 08-30-2025, 09:38 PM   #8
gtstorey
The question is, why would someone have replaced stock injectors with a different injector that isn’t for performance reasons. And are the rest of the injectors the same part#. Not sure why only one of your original seem to have failed? Have you checked fuel trims or any logs from Hpt?
