Old 09-01-2025, 07:57 PM   #1
LavaSurfer
Drives: 2012 Camaro ZL1, 1967 C10
Sping Isolator Damage
Pulled the snout off my SC to replace the isolator and I have a little damage. Should I worry about this amount of damage or just send it?
LavaSurfer is offline   Reply With Quote
Old 09-02-2025, 06:03 AM   #2
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
you're fine, just put a solid one on and send it.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is online now   Reply With Quote
Old 09-30-2025, 08:15 PM   #3
Crankshaft
Drives: 2011 Chevrolet Camaro ss
That looks about normal once the isolator starts making a racket, as the other gentleman said just replace it with a solid one and change fluid while you have the unit out.
download by , on Flickr
Crankshaft is offline   Reply With Quote
Old 01-26-2026, 04:04 AM   #4
jbanks1124
jbanks1124's Avatar
Drives: 2013 ZL1 M6 Coupe Rally Yellow
That looks identical to mine, youre fine, the difference is that when changing to the solid we no longer risk shaving shards of metal into the engine. If youve made the swap to solid isolator already, youre good to go, i just did mine this winter and have been ripping ever since.
An LSA keeps the doctor away!
jbanks1124 is offline   Reply With Quote
