Old 09-04-2025, 12:53 PM   #1
cac0274
Drives: 2012 Camaro 22 Convertible
Headers and exhaust
2012 6.2 convertible, looking for suggestions and vendor for complete exhaust including headers. Anything under $1500?
cac0274 is offline   Reply With Quote
Old 09-04-2025, 02:42 PM   #2
SS_Dave
SS_Dave's Avatar
Drives: 2011 Camaro 2SS/RS
If you want under $1500 for everything, you're probably going to need to go with Speed Engineering. Lots of guys like it fine. Personally, I went with Stainless Power. It's one of the models by Stainless Works. The below video explains the difference.
On Speed Engineering I've seen guys struggle with fitment and then others say no issue. I don't know. Your mileage may vary. And I don't have confidence the finish will look great overtime if that matters to you.
As for other headers, I absolutely doubt you'll see any difference in sound or performance between Stainless Works, American Racing, Kooks (everyone's top choice). And fitment is great on all of those.
For the rest of the exhaust, Corsa and Borla are defacto. But regardless of flavor unless you do axle back only, that alone will be over your budget. You may want to try headers now and leave it stock behind that. You can do headers and a tune in your budget and get both performance and sound. Then later change mufflers or full catback if you want different sound. But that second step isn't going to net you anymore power. Power gains are at headers and either high flow cats or no cats along with a tune.
https://youtu.be/OjCzK4gIteI?si=aw2JGbdRdm995lAh
SS_Dave is offline   Reply With Quote
Old 09-04-2025, 02:48 PM   #3
cac0274
Excellent info, any info on a vendor in our group for works or an engineering?
Old 09-04-2025, 03:51 PM   #4
SS_Dave
SS_Dave's Avatar
I bought my headers from a local shop that also did corresponding dyno tune. You can buy direct from Stainless, but in my case the local shop cut me a better deal. Phastek also has a lot of stuff. Otherwise FB Camaro pages always have vendors trying to make sales.
Old 09-04-2025, 07:18 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Totally agree with Dave on this. I also went with Stainless Power when we did mine many moons ago! I went through a performance shop in my area and they offered me a package deal, headers, offroad mids, install, and a custom dyno tune as well. Cost me 1400 bucks, but that was back in 2012, and with only 12k miles on the car. Now, 12 years later, and 120k miles more, they still look great!! I already had an axle back exhaust back then, so I didn't have to do that. So, yeah, I like the quality of the Stainless Power headers. Back then, I too was on a budget, and that worked for me.
Old 09-30-2025, 08:14 PM   #6
TheBrightSide
Drives: 2010 Chevy Camaro 2SS coupe (MT)
I think it really depends. If you have the budget, then yeah, Stainless Power is a good cheaper alternative. They have fully welded primary tubes at the exhaust port flange, and they also come with high flow cats and adapters for the factory 2.5" inch catback exhaust system. If you end up wanting to upgrade to a 3" inch catback exhaust system, it should be pretty easy to do so.
But if you care more for other parts, and rust isn't a scare in your state/region, then Speed Engineering long tube headers are fine. I actually like those or some of the eBay clones, since those come with "off-road" connection pipes (basically catless/test pipes). The fitment sometimes hits the steering shaft a tiny bit, on the frontmost primary tubes, on the driver side headers. I ended up just marking the spot with a permanent marker, and then hammering on the area with a ball peen hammer (or a mallet, if you need to make a bigger, more flat indent).
TheBrightSide is offline   Reply With Quote
Old 10-01-2025, 05:07 AM   #7
nobodyspecial
nobodyspecial's Avatar
Drives: 45th Ann SS Convertible
I went with a Texas speed 1 7/8 longtube with their matching high flow catalytic converter. I also stayed oem with the rest of my exhaust because I wanted it quiet at highway speed. So far so good. It roars at acceleration and quiets down at 60 mph. My cost was around 1k for the kit, $100 for new oem plugs, $60 for new oem header bolts, and $400 for labor. If your not tuned, then budget some extra for that.
nobodyspecial is offline   Reply With Quote
Old 10-24-2025, 10:26 AM   #8
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
If you want a reasonable, cheap complete exhaust, then Speed Engineering is the way to go. Headers are around $500 with O2 sensors and new GM gaskets, and the catback is $600. Be warned, the cheaper you go, the more likely you are to need to "massage to fit" some of the pieces. It's not a guarantee, but the risk is higher.
Check out my build thread
Old 10-25-2025, 06:26 PM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Also the quality of the steel and welds could be off as well.
Old 11-25-2025, 01:02 AM   #10
InFiD3ViL
InFiD3ViL's Avatar
I bought my Texas Speed long tubes when they were only $600. Times sure have changed. Looking on their website, it seems they don't even sell their long tubes without cats anymore. Their catted headers are $1083.59, for both the 1 7/8 and 2" versions. If I could do it again I would definitely go with the 2" headers...and have them coated.
I would go with Speed Engineering if you want to save money. They also sell a very nice stainless catback system for around $500-600. I almost bought it but decided that I hate having money and went with the $1800 Corsa Extreme exhaust instead. I love it, but sometimes I wish it would just shut up. Texas Speed does have a FULL longtube and catback kit for $1,940.38. Not a bad deal for an entire exhaust, engine to exhaust tip.
Old 11-25-2025, 04:08 AM   #11
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
That's what I went with at first the full kit with TSP and that was about 5 years ago and the headers still look decent. But I wouldn't go to any other dealer then TSP. Some guys have gotten from other dealers and had problems with fitment. I had no issues and did it all myself in the garage.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 11-25-2025, 09:14 AM   #12
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
lol! I hear ya on that one! Contemplating on how to "quiet" mine down a tad with a resonated MF xpipe mid muffler.
Old 11-27-2025, 01:03 AM   #13
VRCamaroSS
Drives: '10 Camaro 2SS/RS
Yeah times have definitely changed. My dad bought the Camaro back in 2011 and he said I was going to get it. Back then I bought the magnaflow exhaust without mufflers for Father’s Day back then was $700. I was given the car this year. That same kit is almost $1700. Of course I am replacing it now with the corsa cause I wanted 3” and quad tips. I should’ve bought more parts back then I would’ve saved more money then I am buying parts now. I went ARH for headers cause I’ve always wanted them. Just got them coated to keep some heat down.
VRCamaroSS is offline   Reply With Quote
