Old 09-08-2025, 10:39 PM   #1
Andresinibus
Drives: 2016 Lt 1985 Irocz28
Lightbulb Lighting issues
Hi guys not sure if I'm in the right section if not can someone move me pls. So here I go I have a 2016 v6 with about 112k miles I installed aftermarket hids years ago and have replaced them a couple times different brands too last set installed about 3 yrs ago I noticed my driver light was out so I swapped bulbs to check if it was the bulb or the balaster looks like the balaster since there's 12v at pig tail but no working light after ordering a new set I noticed my passenger side driving light wasn't working I was like wtf I'll check it on my days off then yesterday while getting home I put the left turn signal and after flashing normal for a few seconds it went into a fast flash so naturally I assumed one of the bulbs went out today after work I check the blinkers and it was the rear one I went to swap it with a new one and after install still nothing so I had my friend step on the brakes and nothing only the middle one and the right one so I had him turn on the lights and to my surprise my passenger parking lights front and back don't work my front driver parking light doesn't work and still my brake/left turn signal doesn't work any ideas greatly appreciated multi switch seems to work as if I turn only parking lights or all lights it shows on dash same as if I turn on or off the automatic light control same for left, right blinkers and hazards everything on dash shows working but not outside thanks again
Andresinibus is offline   Reply With Quote
Old 09-09-2025, 09:58 AM   #2
Andresinibus
Problem solved! If anyone has the same issues it was the fuse for BCM4 in my case on the engine bay fuse box
lighting issue
