Old 09-27-2025, 06:17 AM   #1
Dvloo
Drives: Camaro SS 2ss 2009
Code P0010 & P3401 on Cammed L99 converted to LS3
Lately my camaro has been acting a bit strange, and I’d like to know what could be causing it and how to fix it.
For example, when the car is cold and I start it up, then drive gently in automatic mode, it sometimes feels like there’s a sudden fuel cutoff or rev limiter. This mostly happens below 2000 RPM. The car will occasionally hold back and “hit” a limiter, even though I’m driving smoothly. One time it even happened twice in a row I was going about 50 km/h, and the car downshifted by itself to reach higher RPMs.
Another thing I’ve noticed is that sometimes the check engine light flashes briefly, and even the speedometer drops to 0 and then quickly goes back to the actual speed, which is very strange.
The first time I noticed this issue was after I was driving on the autobahn and on full speed it was like it held back like I it did a fuel cutoff while on automode, after this a month later I had put in a little too much motor oil and then the problem occurred a lot while driving in lower RPM's, Even after removing the excess oil, it still happens occasionally, even a month later.
With HP tuners I get these 2 codes that I can't remove:
0x7E8: P0010 - Intake (A) Camshaft Position Actuator Circuit / Open (Bank 1) (Permanent) 0x7E8: P3401 - Cylinder 1 Deactivation/Intake Valve Control Circuit/Open (Permanent)
My camaro got the following mods:
American racing Longtube headers
American racing X-pipe
GPI SS2 camshaft
BTR Platinum valve springs, Titanium retainers
GPI Hardened Pushrods 5/16"
Trunion Rockers kit
LS7 Performance lifters
L99 To LS3 conversion kit GPI
Oil catch can
Hotlicks flame kit
Here is a google drive link to my HP tuner file so let me know if you see anything weird:
https://drive.google.com/drive/folde...RP?usp=sharing
Dvloo is offline   Reply With Quote
Old 09-27-2025, 03:31 PM   #2
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
Have you spoken with Ryan at GPI? It looks like you're a customer.
Moto-Mojo is offline   Reply With Quote
Old 09-28-2025, 12:47 PM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Agreed, I would run this by Ryan first. See what he says about it.
Old 09-28-2025, 10:44 PM   #4
InFiD3ViL
InFiD3ViL's Avatar
Definitely sounds like the tune is a bit off.
cammed, l99, ls3, p0010, p3401
