Old 09-29-2025, 04:28 AM   #1
Jp757
Drives: Camaro ss
CAMARO DOWN AND NEED HELP!!!
I have a 2010 Camaro ss (L99) I recently got a afm/dod delete on it (active fuel management) new battery, new maf,iat,02 sensors also. But the car will start then die almost immediately after and I have abs and stabilitrack light on with traction control light on to. I have a ob2 scanner, even tho it’s not a top of the line one they use in shops. When I plug it in I’m not getting any codes for them though. Was wondering if anyone can help me out or any ideas.
Jp757 is offline   Reply With Quote
Old 09-29-2025, 07:27 AM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
First thing I'd look at is the MAF, make sure it's the right one in the correct position and plugged in completely. I would also check any other sensor you touched. There's no pending or permanent codes set?
Sent from my Pixel 8 Pro using Tapatalk
Old 09-29-2025, 08:19 AM   #3
Jp757
Drives: Camaro ss
The only permanent codes it has is and the only codes that are popping up also
P0050 02 sensor 1 in bank 2
P0030 02 sensor 1 in bank 1
P0059 02 sensor 1 in bank 2
P0053 02 sensor 1 bank 2
Old 09-29-2025, 09:15 AM   #4
dudamota
dudamota's Avatar
Drives: Twin Turbo 5th gen Camaro
Is this happening every single time ? Or randomly ?
I used to use OB2 scanner a lot, but lately when I am using, when I stop my car and turn it off, the next start I am getting abs,stabilitrack and traction control light on. Car starts but lights stay on.
So I had to turn it off.. Wait few minutes.. and after start it again lights go off.
This situation only happens when I use ob2 scanner.
dudamota is offline   Reply With Quote
Old 09-29-2025, 09:35 AM   #5
Jp757
Drives: Camaro ss
No it’s constantly like that
Old 09-29-2025, 10:40 AM   #6
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
How did you do the AFM/DOD delete? Then check the connections for everything you replaced.
Old 09-30-2025, 03:45 PM   #7
Gen2Dave
Drives: 69 73 camaro
Hello I’m new and haven’t figured my way around .
I’m trying to find the wiring diagram for 5th gen console with gauges ?
Help
Probably need to start my own didn’t mean to hijack sorry as it doesn’t show where to post yet ?
Gen2Dave is offline   Reply With Quote
diagnostic, hellllp, l99 engine, stall at startup, technical issues
