Old 09-30-2025, 08:58 PM   #1
mtnbike2go
Drives: 2014 Camaro Ss
Weird Rear Diff Leak
Hello all. I have a 2014 Camaro 2SS 6speed that has a weird diff leak I can’t seem to find the source of. Last year it started leaking out of the passenger side drive axle so I pulled that and replaced the seal. That fixed the issue until now it started leaking again but not from the left or right axle. It’s dripping off both sides of the black saddle bracket that the diff bolts too and down onto the exhaust pipes. The main seal from the driveshaft looks dry so it’s weird where is all the fluid coming from that’s coming down both sides but not the middle of the saddle bracket?
mtnbike2go is offline   Reply With Quote
Old 10-01-2025, 08:15 AM   #2
fz4k98
Drives: 2013 1ss
Try using a leak trace powder after cleaning the area well. It sprays on clear and turns into a white powder allowing you to see the path.
fz4k98 is offline   Reply With Quote
Old 10-16-2025, 07:21 PM   #3
Rusty Shackleford
Drives: 2012 Camaro 2SS
There's a vent on top of the diff at the rear, on the passenger side. It should have a hose connected to it but it just pulls out of the connector, so it could have come out. You can reach up there and feel for it and see if it's connected. The hose has a p-trap to keep moisture from creeping back up, and so residual fluid finds its way back down to the diff.
That's about the only place I could imagine the fluid could be coming from.
Rusty Shackleford is offline   Reply With Quote
Old 10-28-2025, 08:59 AM   #4
DarylKidd
Drives: Swift 2015
All good now?
DarylKidd is offline   Reply With Quote
leaking, rear differential
