![]() Drives: camaro ss 2010 Join Date: Mar 2023
Sparks wire & long tube headers
Hi
I am confused about the appropriate MSD spark plug wires for a 2010 Camaro with long tube headers ? |
#2 | |
Between long or short wires
Here are the Taylor wires. And the MSD'S you'd use..
https://www.phastekperformance.com/2...ires-79203.htm https://www.phastekperformance.com/2...ires-32829.htm
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 13' 1LE Join Date: Apr 2012
I use the 'truck' race wires from Taylor's; you can angle em so they dont touch the headers. I do have higher valve covers to clear the rockers so I needed em. Regular length ones will fit.
13' 1LE
Old setup: TSP 231-236/Tick 660/.105 PR, UDP, SW LT 2'' & HFC, stock NPP & H pipe, VR-DRX CAI, air scoop, Goertz1 manifold, 102mm BBK, 26" Toyo DRs, Forgestars R17x10 & F18x8, rear seat delete, remote Pat G tune Autocal, 7400 limiter, Spec Mini Twin. 91oct. 11.90@122.3, 0-60ft 2.0 / 11.99@123.6, 0-60ft 2.1 DA+819 ...519RWHP SAE Solid roller SBE LS3, FED, LLSR, 91oct, 605rwhp N/A. Tuned by Pat G. Build by me. |
#6 |
![]() Drives: 2011 Camaro 2SS/RS Join Date: Jul 2021
Honestly, stock OEM are going to be just as good and unless you have odd headers, clear everything just fine. Unless you just want a pretty color are have a massive build, or extra tall valve covers. I run stocks with Stainless Power headers. No issues.
#7 |
It don’t come easy.
Same setup as SS_Dave. I have one heat sleeve on cylinder #1 where that plug wire gets close to the header.
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
I use stock wires with ARH long tubes with no issues. When it comes to wires, don't over think it.
#9 | |
Thanks |
#10 |
#11 |
![]() Drives: 2010 Chevy Camaro 2SS coupe (MT) Join Date: Jan 2024
This is what I did too. I found some different colored ones on Amazon, but were the same specs as the factory AC Delco spark plug wires. The part number was 9478XX (XX = color code?).
I ended up getting AC Delco 9478MM, which were the same as the factory black AC Delco spark plug wires, but just red-colored. They're 7mm thick wires, I believe, but I run heat-resistant spark plug boots/sheathes over the wires, for safety anyways. I also re-used the metal heat shields on the bottoms of the stock spark plug wires, although you can get replacement ones if needed. Some other aftermarket plug wires don't use them. The only time I ever had to run weird angle spark plug wires, was when I had JBA shorty headers, as well as some American Racing shorty headers. The only shorty header I liked, if anyone even cares, were the BBK 1-3/4" shorty headers. I ran the spark plug wires like normal, and the only other clearance issue, was that I couldn't run long bolts the same orientation as the factory headers and downpipes/cats. Yes, I eventually went to long tube headers; and no one should ever have plug wire issues there, since there's usually so much clearance with long tubes. If anything, it's more of an issue to be careful not to chip the ends of the spark plugs, while they're left in the engine while installing new headers. |
