Old 01-31-2010, 10:21 PM   #1
Carlos Garza
Carlos Garza's Avatar
Drives: 2010 Camaro SS RS
Maggie and the fuel pump
I'm thinking about installing a Maggie in my camaro, I would love to run around 8 psi on it. For now, I'm going to run stock internals, cam and heads. What I'm not sure about, is if I should go with an aftermarket fuel pump, or just keep the stock. So all of you guys running Maggies on their cars, are you guys using the stock fuel pump, if not, witch fuel pump do you guys recommend.
thanks!!!
Carlos Garza is offline   Reply With Quote
Old 01-31-2010, 10:59 PM   #2
Bear
Bear's Avatar
Drives: 2015 Green Flash 2SS M6
96% sure that MOST (Not All) of the guys running the TVS2300 are running the stock FP, but they are adding the Maggie larger FIs and a tune. Those 2 things should be good to 500-550 rwhp. Kenny Bell has Boost a pump to aid in fueling if need be.
Back in the Game.
Bear is offline   Reply With Quote
Old 02-01-2010, 12:33 AM   #3
RPM Motors
Drives: LSx's
thanks!!!
Most everyone with a TVS runs thje stock pump and no BAP. However, the fuel pressure does drop to 50-52 PSI above peak torque.
If you are planning big boost or a larger engine with boost, look towards a twin pump conversion or at the very least a BAP.
RPM Motors is offline   Reply With Quote
Old 02-01-2010, 01:57 PM   #4
JM10
Se habla espaņol
JM10's Avatar
Drives: 2010 Camaro SS/RS VR
Anything close or above 600rwhp should have a twin pump or KB BAP?
JM
2010 VR 2SS/RS
BMR Suspension Parts
Hendrix HD Axles
DSS Aluminum Shaft
RPM Diff / 3.91 Gears
LPE ZR1 Clutch
Edelbrock E-Force SC / JRE Fuel Upgrade
Livernois 1C cam 570 rwhp/559 rwtq SAE
Best 1/4 time: 11.43
JM10 is offline   Reply With Quote
Old 02-01-2010, 02:19 PM   #5
mjorgensen
HYPRVPR
Drives: 2008 Viper coupe
What have been the limits of the stock pistons and rods with boost? Has anyone had a ring land failure at more than 6 psi?
M. Jorgensen
WMD
mjorgensen is offline   Reply With Quote
Old 02-01-2010, 03:13 PM   #6
Carlos Garza
Thanks for the info guys. I know a guy that was running around 11 psi on an LS3 with stock internals and his engine is now history. I guess the safest way to do this is to go with 2 fuel pumps.
Old 02-01-2010, 05:58 PM   #7
Speed74SS
Speed74SS's Avatar
Drives: 2010 LPE 650+ CTS-V
I know LPE adds a KB Boost-a-Pump to all their packages over their base package, just to be on the safe side.
'10 CTS-V : LPE 650+ Package 587hp / 582tq
2.55 Upper / 8.6 Lower / ID850's / Kooks Longtubes / New Era CAI
Speed74SS is offline   Reply With Quote
Old 02-01-2010, 06:05 PM   #8
Crowley
Okie doke
Crowley's Avatar
Drives: 2012 GT500
KB BAP here as well
Crowley is offline   Reply With Quote
Old 02-01-2010, 07:31 PM   #9
sweaver
sweaver's Avatar
Drives: 10' CAMARO SS2 LIVERNOIS BUILT
thanks!!!
KB BAP, And now adding new a fuel pump assembly, 8 psi is easy to get on the stock fuel pump until you do heads and cam, Then the boost will drop,
In order to run 8 psi with heads and cam you really should invest in a new fuel pump assembly,
LSx 440ci with KB 3.6 coming soon!
TVS 2300 Intercooled supercharger,
Livernois Custom Tune, 550 RWHP 503 RWTQ
L99 11.02 ET 125 TS
sweaver is offline   Reply With Quote
Old 02-01-2010, 08:53 PM   #10
ADM PERFORMANCE
Drives: Anything I want
We run a KenneBell Boost-A Pump on al of our S/C Cars.
As stated above,anything north of 600rwhp we recommend a little more aggressive fuel system.
Andy
ADM PERFORMANCE is offline   Reply With Quote
Old 02-01-2010, 10:19 PM   #11
Carlos Garza
What about cars at sea level... I forgot to mention my friend was driving the car at sea level when the engine his engine died...
Could driving the car at sea level have anything to do with it?
and what's better the KB BAP or a second fuel pump...?
Old 02-02-2010, 01:59 AM   #12
RPM Motors
Drives: LSx's
Sea level has no bearing -
All BAP's work the same in principal - they raise voltage and since the fuel pump motor is DC the rise in RPM is directly related to the rise in voltage. BAP's are a great value in comparison to adding an additional pump - however, there is a point where they alone can not support the fueling requirements and then a second pump is mandatory. Typically, if you seeing more than 80% duty cycle on 60 lb injectors then the BAP is probably taxed.
Last, adding an additional pump is actually more like "adding a fuel system" and it is not an inexpensive undertaking. I like dual in-tank setups with an external, boost referenced regulator.
Old 02-02-2010, 10:29 AM   #13
jrpxxii
jrpxxii's Avatar
You will be better off in the long run to by a dual fuel pump. You are also able to do any modifications down the road with no worries. I just bought the Fastlane dual fuel pump as my car is very high hp and boost and I am also doing a 418ci forged bottom end as well. I started out with a KB boost a pump but as most will do, I still wanted more and now to be safe I added the new fuel pump.
Old 02-03-2010, 06:40 PM   #14
JBAGREG
Drives: JBA SUPERSPORT 2SS/RS Vortech Blown
Agreed! We installed the Fastlane "Deuce" Fuel pump module with our Vortech V3 on the JBA Super Sport and have headroom up to 800 hp. When it comes to fuel, don't mess around. It's cheap insurance relatively speaking.
JBAGREG is offline   Reply With Quote
