![]() Drives: 2014 Camaro 1LE Join Date: Oct 2025
Unlowering an 2014 1LE
Hi
Just got my 2014 1LE, loving the car, it was a massive change from my 2010 2SS. I only know of two 1Le here in Norway, and i have one of them ![]() The previous owner put on some lowering springs on the suspension, with state approval (Norway) and everything, but i feel the ride is to low for our roads where i live. Does the 1LE share the springs with regular SS? Partnumber for them so i can order some new ones? havent had any luck on ebay soo far. Thanks |
Tri-County Camaro SWFL
1LE does share SS springs. No difference there
https://www.camaro5.com/forums/showthread.php?t=244570
![]() Drives: 2013 Chevy Camaro 1LT Join Date: May 2022
Have you considered aftermarket adjustable coilovers?
That way you could dial in the ride height where you want it. Less likely of hitting a "discontinued part" dead end or bad used parts on ebay. They're no to difficult to install yourself. Like I did here: https://youtu.be/9Uzd6kuE2XQ?si=wMMxDa-zcwdeN-Wi |
