![]() ![]() ![]() ![]() Drives: 2012 Camaro SS Join Date: Dec 2019
Help me build my rear suspension
Have been looking at BMR parts since Detroit speed looks amazing but very expensive and my car is just a weekend warrior. Would it be worth the extra $1000 for Detroit Speed? And is adjustable even worth it?
What I am looking at with BMR - TCA027 2010 - 2015 Chevy Camaro Trailing arms, rear, spherical bearings Color: Red $229.95 1 $229.95 Remove Item TR002 2010 - 2015 Chevy Camaro Toe rods, rear, non-adjustable, polyurethane bushings Color: Red $189.95 1 $189.95 Remove Item TCA028 2010 - 2015 Chevy Camaro Lower Control Arms, Rear, Non-adjustable, Poly Bushings Color: Red Grease: SUL-41150 - 14oz Super Lube(+$18.95) $399.95 1 $418.90 Click to remove the item from your cart. To add quantity to a product, enter the qty you would like in the qty box, then click Update Qty. Total: $838.80
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
![]() Drives: 2011 Camaro 2SS/RS Join Date: Jul 2021
So I just did my rear end. May add more, but a couple of things...
Spherical, though good, tend to be noisier than poly. TCA028 - Those LCA's are shorter than stock. They are meant for cars that are a bit lowered. And you're going to need the adjustable toe rods and end links to accommodate for them. Here is what I have on my car in addition to Pedders coilovers. Front end additional changes are next for me. TCA028 - LCA's. TR003 - Adjustable Toe Rods trailing arm not required. I may change at some point, but don't expect much of any difference. ELK006 - end links. I haven't bothered changing the actual sway bar yet. BK024 - Cradle bushings BK029 - Diff bushings |
#3 | |
Thank you so much. Bmr descriptions arent the best and was unsure of which to get. I will do the diff and cradle bushings when I get the gears changed. I did hit a curb over a year ago and want to change all rear parts in case something is bent. That’s why I was gonna do the trailing arms too
Without checking the numbers, Check Spohn.
They have some of the same parts for the Camaro that you are looking at.
2011 2SS/RS Convertible, Victory Red, Roto-Fab CAI, Stainless Power 1 7/8 headers, No Cats, Straight piped, Bo White TB, Circle D, 3.91, ZL1 CONVERSION, CDC Roll bar and some powder coating and dipping.
And check your rear wheel width.
I am finding that these rear lower control arms do not fit wheels wider than 9 inches. This is stated on some of the manufacturers website. Sucks, mine are 11inch.
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
I skipped the LCAs and used factory FE4 units (2012 and later) in both my cars. Most guys do fine with stock LCAs and the need to change them comes in when you want to go to a 15 inch wheel for drag racing.
Full disclosure, both my cars are only lowered half an inch in the rear. I don't see any sway bar changes, and I would definitely spend money there first. I run a 27/32 setup on the vert with 1LE shocks and a 25/28 setup on the turbo car with Z28 shocks and springs. The turbo car does have some understeer due to the staggered tires, but for where I am at right now, it's better that way.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
#7 |
In my case, I'm running 20x11 and 315/35/20. I am lowered somewhere around 1"- 1 1/4".
#8 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
I have full BMR rear suspension, One thing I wish I had done was use their adjustable rear lower control Arm instead of their fixed unit. I had to really work to get my Alignment specs ( Would not have been an issue with my stock or adjustable ones but their fixed unit it is )
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount. |
#9 |
Thanks everyone for the feedback!
#10 |
Does this all sound right - what I'm looking to order
BMR-TCA026R - Trailing arm BMR-TCA028R - lower control arm BMR-TR003R - adjustable toe rod And this sway bar https://detroitspeed.com/detroit-spe...-kit-042221ds/ The Detroit speed other products look really solid, but the prices are crazy and i feel like the bmr ones are probably just as good for my needs.
#11 |
Looks good. I have to ask. How many miles on the car? Cradle bushings can make a big difference. Think about it. Everything you're doing is attached to the car holistically at the 4 cradle points. A good amount of lateral movement can come from here. I would upgrade those bushings to BMR poly or solids.
#12 | |
#13 |
So those are the lca that i run but if I was doing it over I'd get adjustable ones, if lowered and trying to get a decent alignment spec you'll need adjustable camber bolts as you'll run out of factory adjustment and even then I needed to make more modifications.
#14 | |
Now time to try and find a coupon code that works lol
