![]() Drives: 2010 Camaro SLP ZL575 Join Date: Oct 2025
2010 SS Getting ZL1 Gen 5 Calipers Help
Ok my wife has a 2010 Camaro ZL575 that came with the upgraded SLP Brembo kit but they are still 4 pots. We track and autocross the car so im upgrading to bigger brakes. I have purchased 5th gen ZL1 calipers and rotors. Before I start this swap, I just want to make sure that ordering gen 5 ZL1 Brake lines is all I need? The rears are the same as the ZL1 so im just doing stainless lines all the way around. Any advice or something im missing?
The dust shields are different you cut your originals or order the actual ZL1 look in the 1LE forum there’s a ton of info there.
Orange Krush II
You da man. Ok Ill check that out. Thank you very much.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
Good luck finding those dust shields. You will likely have to just do without them.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
Yeah that has been the outcome so far. I cant find anything and the sad thing is, the car I bought those calipers from had the dust shields but at that time I didnt know I needed them and they were 4 hrs away...
Devon Kelly
Anderson, SC |
