Old 10-29-2025, 06:37 AM   #1
tlamb2
WHPLSH
tlamb2's Avatar
Drives: 2010 SS Maggie,ARH,Meth, BTR stg2
Upstream 02 sensor after cats?
So I threw a P0134 Code. 02 sensor bank one sensor 1. So I picked up an Upstream 02 sensor, and when I went to replace it, the downstream sensor was in the Header bung, and the upstream was behind the cat, so I just replaced it and left it in the rear. And the CEL went away, and both banks are the same. I have headers, so I knew the rear were deleted in the tune, but why are they in the header? I contacted the tuner who did the header tune, and he said it goes first in line. I had the headers installed 14 years ago, and since then, have added Maggie, Meth, and a stage 2 blower cam, three tunes total. Does it make any difference to have the upstream sensor behind the cats?
tlamb2 is offline   Reply With Quote
Old 10-29-2025, 07:54 AM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I don't see how your ECM can control fuel delivery if it is behind the cat, which would be catalyzing unspent fuel. In other words, a working cat will make the sensor behind it unable to sense a rich condition. Your car has probably just been running rich for 14 years, or maybe it just runs in open loop because the ECM sees feedback that makes no sense to it. Surprised you don't have a CEL.
Old 10-29-2025, 07:58 AM   #3
tlamb2
WHPLSH
tlamb2's Avatar
You would think the tuners would see it right? Now, when I move them up, will it mess with the tune?
Old 10-29-2025, 07:59 AM   #4
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Can you send me your tune? I'm curious. The O2 sensors that are controlling fueling are best positioned closest to the exhaust valve. If the secondary's are actually off in the tune then he's just using them as a plug for the hole, but why the active ones are downstream of the cats is a mystery to me. Moving them would most likely upset the tune so I wouldnt do that without talking to your tuner.
FasNuf is offline   Reply With Quote
Old 10-29-2025, 02:29 PM   #5
tlamb2
WHPLSH
tlamb2's Avatar
FasNuf, I will get a copy of the tune from the tuner and send it to you when I get it. It will be a week till I get out there. Thanks for your input. It was funny when I was reading your reply; I was also watching your YouTube video on installing your wideband gauge. You have a great channel on YouTube, keep up the good work.
Old 10-29-2025, 02:40 PM   #6
FasNuf
FasNuf's Avatar
Thanks!
I sent you a PM
Old 10-30-2025, 12:40 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Agreed with both of the guys above on the upstream 02's, they need to be "before" the cats to work properly with the ECM..
