![]() Drives: 2010 Synergy Green Camaro 1LT Join Date: Jun 2019
Starting wishlist for Xmas. Lower springs
So I am looking at adding lowering springs to the wishlist for Xmas.WIfe is already pushing the issue LOL.
Looking at 2 options , the PFADT 1.2 drop , or the BMR 1.2. Don't need anything aggressive like a coil over , for she is my everyday driver , not doing any track , and I am looking to close the wheel gap without a rough ride. Leaning towards the PFDAT , because they are calibrated to work with the stock suspension. Since I am running a 275/40/20 20x10 MRR 1LE reps with the +23 off set up front , 20x11 315/35/20 +43 out back , am I looking at any rubbing concern? Mostly in the front? Thanks for any input ! |
#2 | |
#3 | |
Well it was a really bad rub where the inner sharp metal fender edge actually cut the tire where the tread meets the sidewall. I don't have any pics, but I had to replace both the fronts with the 285/35's.. Damage to the fender never happened, it just would move the inner plastic liner out of the way and expose the sharp edge of the metal fender.
![]() Drives: 2012 Camaro 2SS Join Date: Jun 2023
Add a set of Hendrix offset differential bushings to the list. They'll help keep the axle angles happy when you lower the car. It's a bit of a project to pull the diff and get them swapped in, but worth the peace of mind for me.
I'm on BMR 1.25" springs and they are about the perfect ride height for me. Ride quality isn't terrible, but noticeably stiffer. Hard to tell because as a baseline I already have Pedders front and rear sway bars |
#6 |
![]() Drives: 2013 ZL1 Join Date: Nov 2018
These are the 1 inch BMR's.
2015 1SS 1LE, Magnuson 2300 Heartbeat and headers. 550rwhp STD, 535 SAE.
#7 | |
#8 | |
#9 | |
#10 |
#11 |
Mine has Asanti Dynasty wheels, 20x10.5" rear w/35mm offset and 20x9" w/38mmoffset and a 9mm spacer (so 29mm offset total) front. 305/35 rear, and currently 275/40 front. Will be 275/35 front when I get new tires. Last edited by Rusty Shackleford; 11-08-2025 at 09:48 PM. |
