Old 11-03-2025, 06:36 PM   #1
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Any Strut tower braces that fit an SS with an LSA and stock hood?
Hi, Most likely am going to be swapping an LSA onto my 2014 LS3 SS and wondering if there is a brace that fits?
Thanks
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 11-03-2025, 09:54 PM   #2
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
what about the factory zl1 brace? joe
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 11-03-2025, 10:12 PM   #3
Joe.G
Joe.G's Avatar
So I have been researching a little, I read that the SS Brace that I have now should work if I space it up a little But I have not confirmed this yet from any other posts. The ZL1 Brace I believe needs the ZL1 hood or aftermarket option to work once again not 100 % sure.
Old 11-05-2025, 08:17 PM   #4
Ashen L99
Ashen L99's Avatar
Drives: Ashen grey, 1SS, L99
Can confirm this, zl1 brace needs zl1 hood. I got the kong gen 3 lid, and it fits with no spacers on the SS brace.
Roto-fab big gulp, Nick Williams 102mm TB, Kong X-port LSA, Ported 821 heads, BTR stage 4 V2 pd cam, 416 CI bottom end, original block. TSP 2” long tubes, Corsa ZL-1 catback. Nitrous Outlet 102mm plate kit/100 shot JUST IN CASE. NGK BR7EF plugs with Taylor plug wires. DSX flex fuel kit, DSX aux pump, zl1 in tank. deatchwork 1000cc injectors. B&M deep trans pan, stock 6L90 converter, ZL1 diff 3.23 ratio. GM ground effects, T-Rex upper grill, Z/28 Spoiler, Forgestar F14s, 12” subwoofer, and custom paint matched interior.
Ashen L99 is offline   Reply With Quote
Old 11-05-2025, 08:49 PM   #5
Joe.G
Joe.G's Avatar
I am not familiar with that lid is it much different than the LSA? If I can just space mine up I'd do that.
Old 11-06-2025, 06:30 PM   #6
Ashen L99
Ashen L99's Avatar
Yeah, it is lower profile. Space your SS brace up, Hammdo did the same I believe.
Old 11-06-2025, 07:08 PM   #7
Joe.G
Joe.G's Avatar
Yeah I read like a 5/16th spacer would work so it doesn't have to go up much.
Old 11-06-2025, 08:28 PM   #8
tartagliazl1
joe, if that's all you need just mill the lid. just like the ctsv guys have to do to run the zl1 lid on the V. plus I'm sure you will change the red lid color anyway.
Old 11-06-2025, 09:05 PM   #9
tartagliazl1
you could also buy the BMR motor mounts and lower the engine 1\4" by leaving the spacer out.
Old 11-06-2025, 09:23 PM   #10
Joe.G
Joe.G's Avatar
Yeah I am just getting ideas together, I'll be painting the lid as well, not sure black or car color.
Old 11-07-2025, 01:08 AM   #11
ariZona28
Give speed a chance
ariZona28's Avatar
Just get the ZL1 hood and strut brace. No MacGyvering required.
ariZona28 is offline   Reply With Quote
Old 11-07-2025, 06:32 AM   #12
Joe.G
Joe.G's Avatar
Not really a fan of the ZL1 hood, I don't hate it but prefer the look of the SS.
Old 11-07-2025, 11:13 AM   #13
Jeff_SS
"Cam Only"
Jeff_SS's Avatar
Drives: 2013 Camaro SS
I have a factory SS strut tower brace with the LSA and stock hood. Just a few washers on each side to raise it up a tiny bit and it's good to go.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq
Jeff_SS is offline   Reply With Quote
Old 11-07-2025, 11:52 AM   #14
Joe.G
Joe.G's Avatar
Perfect thank you
