Old 11-07-2025, 04:08 AM   #1
slipknotdude
Drives: 2013 Camaro LS
2013 LFX V6 Tune Up
Hey all, so my Camaro is at nearly 130,000 miles. It doesn't seem like the previous owners really did much with it as far as maintenance goes. I've already changed the oil/coolant (I'm also having cooling system issues right now, water pump is leaking. Already bought a new one so that's out of the question), but I'm wondering what all should be done concerning a tune up? Asking as this is my first vehicle and I'd like to take better care of it than previous owners as far as maintenance goes.
Edit: Also to note, at idle the engine tends to sort of "pulse". It's been doing this since I got the car and I'm not at all sure what's causing it.
slipknotdude is offline   Reply With Quote
Old 11-07-2025, 11:18 AM   #2
xstuntman
Drives: 2012 Victory Red LFX
I'm thinking the pulse is the idle moving up and down from a leaking fuel injector. A good cleaning might help but at 130k i would think on replacing all of them with new GM injectors. Fifth gens sometimes have problems with after market injectors I've read.
An upper cleaning of the throttle body and intake valves would also be a good idea. DI motors usually have carbon heavy intake valves as no gas every goes past them. I used to use Sea Foam but switched to CRC.
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
xstuntman is offline   Reply With Quote
Old 11-09-2025, 02:53 AM   #3
Indian_Mack
Indian_Mack's Avatar
Drives: 2013 Chevy Camaro 1LT
New plugs might be in order as well. After all the above and the plugs, consider a trifecta tune. Really woke my 13 v6 up. They could run through a data log and give you insight on any further issues.
Indian_Mack is offline   Reply With Quote
Old 11-09-2025, 04:18 AM   #4
slipknotdude
For cleaning the intake valves would I need to remove the heads?
Old 11-09-2025, 03:17 PM   #5
xstuntman
No.
There are vids on the 'tube that show how to spray thru the intake tube when cleaning a DI.
