![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
Aftermarket Heat exchanger Options what is the go to these days?
Hi,
I am just starting to put together the parts for the LSA swap onto my LS3. I have a res and pump but I am missing the Heat ex changer. I am leaning towards a Afco unit but would like to hear others thoughts. If I go Afco fans or no fans? I have read pros and cons but mostly on Mustang forums. Are the fans really loud? I don't think that is something I would want to hear all the time. May add a cam down the road but I am assuming power with LSA swap would be in the 500 to 550 Range? Thanks
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount. Last edited by Joe.G; 11-08-2025 at 08:30 PM. |
![]() ![]() ![]() Drives: 2013 zl1 vert Join Date: Dec 2018
When i had the afco with fans installed on my zl1 it would keep the ait2 about 13 degrees above ambient temperature while cruising. I can’t say what it would be without the fans. The fans are loud but you wouldn’t hear them when you’re are driving. They tap into the intercooler pump power wire, so anytime the pump is on the fans are on. I had it set up in the tune to turn on both with acc on. That way it still run while the engine is off to continue cooling.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
I am not exactly sure how much the heat will affect a street car, Wondering if the extra wires/clutter and noise is worth it or not. I am assuming the more power and the harder you are on the car the more the fans would be needed. My car would not typically be in a stop and go traffic type situation either.
AeroForce Dual gauge/Autometer pillar mount. |
![]() Drives: 2010 camaro ss Join Date: Aug 2021
I’m running a plm heat exchanger on my Lsa swap car. Been super happy with it.
https://privatelabelmfg.com/products...harged-6-2-lsa Sent from my iPhone using Tapatalk |
Fit was good? Any modifications to make it work?
#6 |
#7 |
![]() Sent from my iPhone using Tapatalk |
#8 |
Thanks i'll add that to my list to research.
#9 |
"Cam Only"
I have the prospeed heat exchanger. It's good.
If I were in the market again I'd get that or I'd hit up Cordes Performance Racing and see what offerings they have for the 5th gen.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq |
#10 |
I'll take a look thanks.
