Old 11-10-2025, 10:18 AM   #1
Z ya later
Drives: Z/28
AiM ODBII cable problem
I have a 2015 Z/28 that I am having a weird problem with my AiM data logger.
When I connect the AiM OBDII cable to the port in the car it won't start. It does not matter if the cable is connected to the Solo 2 DL v2 or not. The car will start as soon as I remove the cable from the OBD port.
Has anyone been able to get data from the OBD to a Solo2 DL v2 ?
I am thinking it might be a bad cable somehow.
I am trying to get data from the OBD and pair it with a Solo 2 DL, Smarty cam Corsa and a shift light module.
It looks like there is not a Z/28 protocol available as a drop down selection in the configuration in Race Studio 3. I have all the latest firmware and software updates installed.
If you have any solid experience with making this work properly, I'd really appreciate the input. I have used AiM with my dedicated race cars and can't seem to make this work in the Z/28 with OBD
Z ya later is offline   Reply With Quote
Old 11-10-2025, 11:28 AM   #2
FASTFATBOY
Drives: 2013 ZL1
Anything else in the car not work? Check the ALDL fuse first.
2015 1SS 1LE, Magnuson 2300 Heartbeat and headers. 550rwhp STD, 535 SAE.
FASTFATBOY is offline   Reply With Quote
Old 11-10-2025, 11:46 AM   #3
Z ya later
Drives: Z/28
Everything else works perfectly. I will check that fuse tonight.
The car will start up normally as soon as I remove the cable from the port.
Old 11-10-2025, 11:48 AM   #4
FASTFATBOY
Drives: 2013 ZL1
Anyone else at the track or close have an AIM cable you can borrow?
Or a Bluetooth dongle? Or a HPTuners cable?
Go to Autozone and see if it will crank with their code puller plugged up.
Old 11-10-2025, 02:08 PM   #5
gtstorey
This very much more than likely a short in the cable.
gtstorey is online now   Reply With Quote
Old 11-15-2025, 06:55 AM   #6
Z ya later
Drives: Z/28
The cable was the problem. I bought a new cable, and everything works normally now.
Old 11-15-2025, 05:00 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Very cool! Thanks for letting us know the outcome.
