![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
LSA SC on LS3 Stock Lower 2.55 upper Okay?
Hi,
So as you guys know i I plan to Install an LSA on my LS3, the kit I purchased has a 2.55 upper and I plan to grab a stock LSA lower IS this combo okay? I have a Ported LS3 TB and Headers with a CAI otherwise motor would be stock. I plan on running a ZL1 Fuel Pump and upgrading the LSA injectors. Thanks
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount. |
![]() Drives: 2013 Chevrolet Camaro ZL1 Join Date: Jun 2025
Depending on your shift point, a 2.55" should net you around 11-12psi. Not sure how a stock bottom end LS3 can handle that as I currently have a 2.55" upper on my ZL1 (14psi with Kong Port). Depending on your power goals, the ZL1 pump and injectors might not be enough for you...
Sent from my SM-F966U1 using Tapatalk |
I plan to purchase different injectors to be safe, not sure which ones yet.
Ethanol isn't easy to find around here so I have no plans to , power I'd like to be some where in the 550 to 600 range. I am not sure what to do pulley wise.
#6 | |
#7 |
Sounds good will do.
#8 |
Anyone else have any ideas on what would be a good Pulley size to run? 2.55, 3.00 or something in between?
#9 |
I am looking at a 5% ATI lower Balancer pulley combo, How does that change things, If 2.55 isn't a good choice is there another I should try? I do want a safe combo and also would like the most I can get out of it.
Thanks
#10 |
"Cam Only"
These are questions you should really ask whoever is tuning your car.
You can read my signature to see what I did on my LSA blower setup on my LS3. 2.5 upper and 10% lower. I have a flex fuel tune. Can run 91 or full race E85.
2013 AGM Camaro 2SS/RS M6 | LSA Blower, 2.5" pulley, 10% lower, FIC1000's, Fore Innovations Twin Pump fuel system w/ Flex Fuel, CMS Custom Grind Cam, Kooks 1 7/8" headers w/ catless off-road pipes, NPP Exhaust, 3.91's, JLT ZL1 Intake, Prospeed Heat Exchanger, Monster S Series Triple Disc Clutch | Pfadt Suspension, 1LE Sway Bars | DSS 1000hp axles | Mickey Thompson ET Street R 305/45/18 |
Tuned by Ryne @ CMS E85: 734rwhp/674rwtq |
#11 |
Yes I have been in contact with my tuner and I am taking his advice but I do like to do my own research and try to learn as much as possible, and then Him and I can discuss it and come up with a plan that we both agree on.
Jeff You run that set up on a stock bottom end? I am looking for a nice all around set up.
#12 |
So I have a 5% ATI lower Balancer pulley ID1050X injectors Going to run a ZL1 pump Thinking a DSX aux pump and a PD Cam ad headers does this make the 2.55 upper Pulley a safe choice to run now? I did speak with ADM since a lot of the LSA conversion parts came from them and they said it is a combination they use often.. I don't want to bother the tuner with every question I have at the moment.
#13 |
"Cam Only"
If you're going through all this trouble, you should just do a full Fore Innovations fuel system. As I've said in some of your other threads, buy once cry once. I'd rather go overkill and have a higher ceiling for the future or for just more safety.
Things to never go cheap on with cars: Tires Brakes Fuel systems
#14 |
Is the DX Aux pump along with the Zl1 pump not capable of my power goals? I was looking into the Fore set up and there were a bunch of different Options even with Pri and Sec pumps.
I am hoping to get to the 650-700 HP Range.
