Old 11-12-2025, 10:31 PM   #1
Shyster
Drives: 2013 Chevy Camaro SS
Unhappy Major oil leak 2013 Chevy Camaro 2ss
I have a 2013 Chevy Camaro SS. I recently did my oil change and noticed 2 quarts missing. There was oil residue along the valve cover so I replaced that with the built in Pcv valve. I also replaced the oil pressure sensor/switch. It didn’t fix the issue. There seems to be a lot of oil that drips. It’s not a small drip either it seems to be continuous. I took pictures and a video and I can’t pin point the exact location of the leak.
First pic is taken from above behind manifold near the oil pressure sensor.
Shyster is offline   Reply With Quote
Old 11-12-2025, 10:47 PM   #2
Indian_Mack
Indian_Mack's Avatar
Drives: 2013 Chevy Camaro 1LT
Is it on the same side as the oil filter? I had a bad seal on a filter last oil change, and caused something similar.
Indian_Mack is offline   Reply With Quote
Old 11-12-2025, 11:32 PM   #3
King Nothing
Turning wrenches
King Nothing's Avatar
Drives: 2011 Camaro SS By Berger 11BC21
Remove your intake manifold and it might be the valley cover. That’s my guess.
Sold-2006 Pontiac GTO
M6 1 of 475
353rwhp 353rwtq
Sold-2000 Camaro SS A4 Hardtop #867 of 8913
1 of 103 Bright Rally Red Hardtop SS A4 in 2000
1 of 25 and only SIM Camaro By Berger in 2011 year, 2011 Camaro 2SS/RS M6 By Berger #11BC21
King Nothing is offline   Reply With Quote
Old 11-13-2025, 07:55 AM   #4
Shyster
I don’t believe it’s that seal as I’ve looked.
Old 11-13-2025, 07:56 AM   #5
Shyster
I never even thought of this. It does look like the rear valley cover.
Old 11-13-2025, 12:11 PM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yep, this just might be your problem. I've read about this on here before. I did have it happen way back, and the other area I had a problem with was the rear of the passenger valve cover, but I saw you already did that. I'll bet like king said, it's the valley cover. Good luck!
Old 11-25-2025, 10:43 PM   #7
Beauwulf
Beauwulf's Avatar
Drives: '10 LT RS A6 & '04 Acura RSX Type S
That last photo looks like the oil pressure line that goes up to the cooler from the block. There's an "O" ring on it which is likely dried out.
Beauwulf is offline   Reply With Quote
Old 11-26-2025, 06:20 AM   #8
Shyster
Well there was dried up oil along the tray when I took the intake off. So I’m hoping it’s that.
Old 11-26-2025, 08:28 AM   #9
Beauwulf
Beauwulf's Avatar
It's an easy fix to pull the one bolt out holding the line in and change out the O'ring. Worth doing if you in there anyway.
2013 camaro, help me please, leak, oil analysis, oil leak
