Old 11-14-2025, 06:54 PM   #1
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
Roto Fab VS Roto Fab Big Gulp Vs CAI on and LSA SC set up Which one?
I'll be adding a LSA SC to my LS3 and will hav to replace my current CAI brand intake, Regular Roto Fab VS Roto Fab Big Gulp Vs CAI.
Pros and Cons of each.
I always preferred the look of the CA brand and it worked well with the scoop. I see a lot of people lean towards the Roto Fab so I am wondering which you guys think.
Thanks
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 11-14-2025, 07:21 PM   #2
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
jlt makes big power for the price. im currently Roto Fab big gulp. ive had the Jlt, RPM 5" and also the Vararam intake. if i had to rank them it would be:
1. roto fab 5" big gulp
2. jlt 5'
3. Rpm 5"
4. Vararam. 4"
The 5" are for big HP combo's if you are ok with under 700hp I would go regular roto fab. If i were you i would just go with the Jlt intake for the cost $290 car ran great with it and made 738 HP. 750 tq.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 11-15-2025, 07:25 AM   #3
Joe.G
Joe.G's Avatar
Thanks for the suggestions, Is there any reason to get big gulp If I don't plan to break the 750 range? Regular Roto Fab will cover up until then?
Old 11-15-2025, 07:59 AM   #4
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
Big gulp = big power
Check out my build thread
Old 11-15-2025, 09:32 AM   #5
tartagliazl1
I would take the jlt over the regular roto fab. Don’t be like me, buy once lol
Old 11-16-2025, 07:10 AM   #6
Joe.G
Joe.G's Avatar
Is there any reason not to run the Big Gulp? Is it a waste and my set up can't use all the extra air? Do any of these change the sound of the SC?
Old 11-16-2025, 07:19 AM   #7
divine_godly
divine_godly's Avatar
Drives: 2013 Chevrolet Camaro ZL1
The big gulp requires atleast a 102mm Throttle body. To have a 102mm Throttle body on an LSA requires the snout to be professionally ported as it can only fit a 90-92mm. You can have an adapter to fit a smaller throttle body but you would essentially bottle-neck the big gulp which negates the point of having it. Its also a little much unless your going for like 650+ whp. Regular Rotofab is more than good enough for anything under 650whp.
13' ZL1 Auto: CAI, 95mm TB, Kong Port, 2.55 upper, DSX Aux Pump, ID1050x, Kooks 1-7/8 LT/HF Cats, Corsa Cat-Back, Catch Can, 160 Therm, NGK Plugs, MSD Wires
divine_godly is offline   Reply With Quote
Old 11-16-2025, 07:23 AM   #8
Joe.G
Joe.G's Avatar
Gotcha do the other 5 Inch ones listed above require adapters and what not?
Old 11-16-2025, 07:42 AM   #9
divine_godly
To my knowledge all 5inch duct intakes require atleast a 102/103mm TB or you will need a drop-down adapter. but definitely double check on the manufacturer website
Old 11-16-2025, 08:09 AM   #10
Joe.G
Joe.G's Avatar
JLT Appears to be apart of S&B which I run their CAI on 3 Dodge Ram Pickups, A 5.9 Cummins,6.7 Cummins and a 5.7 Hemi and they are top notch at least for the trucks. I honestly like the look of the CAI brand currently on my camaro and with the Scoop you noticed a difference.
Old 11-29-2025, 08:09 PM   #11
Joe.G
Joe.G's Avatar
Does anyone have any experience with the CAI Brand with the cold air scoop and a Supercharger, I am listing to the suggestions made but I really do like the look of the CAI brand, and I know on NA builds it is well regarded but wondering about FI.
Thanks
Old 11-30-2025, 09:28 AM   #12
hesster
hesster's Avatar
Drives: '10 T/A Conv, '10 2SS, '77 SE T/A
Thanks
That is the set-up I run. Whipple, Blower Cam, 3.75" Pully, etc. And the cold air Duct. Tuned by Ted Jannetty. About 750 HP and 680Tq with a mild tune. I took extra steps to totally seal and insulate the Air Box and Intake Pipe. The LEDs inside the box are good for a extra 5 HP Runs like a monster.
hesster is offline   Reply With Quote
Old 11-30-2025, 10:21 AM   #13
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
I’m running a reg roto-fab intake . Was told by my tuner ,it was not worth it unless I get up to bigger cubes ,only so much air can go into our cylinders .
Although,I do see a lot of people running the 5” intake ,I’d definitely would love to see a comparison .
I have fully ported lsa w nw 103mm
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.5@135
Risingson05 is offline   Reply With Quote
Old 11-30-2025, 11:26 AM   #14
FASTFATBOY
Drives: 2013 ZL1
Who makes this setup? I saw it the other day and now can't find it.
I would assume this works with any CAI?
2015 1SS 1LE, Magnuson 2300 Heartbeat and headers. 550rwhp STD, 535 SAE.
FASTFATBOY is offline   Reply With Quote
