![]() Drives: 2011 v6 Camaro Join Date: Nov 2025
after driving for a while I eventually get the engine temp high warning - idle engine. then after a little more stop engine. THe gauges in the middle next to the gear shifter read normal but the guage in the dash goes to max and then back to normal randomly. We started by replacing the radiator and fan but it kept happening so we replaced the thermostat. It is still happening anyone know of any fixes?
The car goes into limp mode sometimes which disables power braking and steering which is so dangerous esp when im on the parkway. The car isnt actually overheating it just thinks it is. |
![]() Drives: 2013 Chevy Camaro 1LT Join Date: May 2022
That makes me think there's a fault with the temperature sensor.
Wifey Lover
Drives: 2013 2LT to 2SS Manual Conversion Join Date: Nov 2011
This
First, check the wires and connections. If they are good, a replacement sensor is fairly cheap... install videos available on YouTube
https://www.autozone.com/engine-mana...500/577556_0_0 |
![]() ![]() ![]() ![]() ![]() Drives: '10 LT RS A6 & '04 Acura RSX Type S Join Date: Oct 2009
If your still effing with this, there is a chassis ground for the instrument cluster that might be loose or corroded. If memory serves, it under the left side dash behind the left outer kick panel.
