![]() Drives: 2015 Camaro 2SS 1LE Join Date: Dec 2019
1LE spindle nut?
My rear right spindle nut on the axle loosened up the other day, since they're 1 time use I ordered a new one from the parts house. However, the one I received was much smaller in internal diameter than the one that came off. Does the 1LE have a different spindle nut? If so does anyone have the part number? The parts store only shows the one they had in stock.
Pic of both side by side
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
I had a a 2014 1LE, Here is the part # that I used, same as what your original was:
#11611234 Definitely stake the new one like the old.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
"KEEP THE FAITH"-Fbodfather |
Thank you so much! I contacted the dealership yesterday, before I saw this and had one ordered for my 1le. I'll match the part numbers before I buy it! Thanks again!
#6 | |
#7 |
![]() Drives: 2013 ZL1 Join Date: Nov 2018
1LE has ZL1 axles is why.
2015 1SS 1LE, Magnuson 2300 Heartbeat and headers. 550rwhp STD, 535 SAE.
#8 |
Uh no they don’t have the same axles,
The inner splines that go into the diff are different. The outer splines are the same as SS,1LE, and Z28. An CV joints and shaft diameters are different as well.
Orange Krush II
#9 |
Pretty sure the 1LE also has the ZL1 wheel bearings, so that part would be the same as far as size go.
Which would be the bigger nut.
#10 |
![]() Drives: 2013 Chevrolet Camaro ZL1 Join Date: Jun 2015
The 1LE and the ZL1 share the same axles
32 inboard splines, 33 outboard splines, same wheel bearings with an axle nut of 27x2 mm If you see an axle nut of 24x1.5 mm that is for an SS |
