Rear Upper Knuckle Bushing Replacement
There are no service parts for the rear knuckle. GM service procedure is to swap out the entire knuckle assembly, which is NLA. I had some lateral slop in my rear knuckle bushing, so I began searching for a solution. Someone on Facebook suggested I try a bushing specified for a Jeep, which was a remarkably close match. I pressed it in to the knuckle without issue.
The bushing I used is MOOG K201552, cross-reference to MOPAR 5105272AA and others, used in Jeep Liberty. ![]() ![]() ![]() The major dimensions of the Jeep bushing match the OE GM bushing exactly. The only difference of note is the lack of flange on the Jeep bushing, but the only appreciable difference that causes is more care is required when pressing in the bushing to not overdo it. ![]() ![]() ![]() ![]() ![]() ![]() I used a tool rental ball joint press from my local Autozone to press in the new bushing. No issues. ![]() I then sent the car sideways. Bushing is holding up fine. ![]() The Jeep bushing isn't specified anywhere in the literature whether or not it's a spherical bushing or a conventional bushing, but some product images from Moog suggest that this is a spherical bushing.
![]() Drives: 2011 Camaro 2SS/RS Join Date: Jul 2021
Awesome info!!!
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
I don't understand why the aftermarket hasn't jumped on making a replacement, this i going to be a sort after part I would think.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
Thanks for posting this.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
#5 | |
Drives: Camaro Justice Join Date: Jun 2007
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2022 1SS 1LE A10 BCD WCT+PDR Join Date: Mar 2008
It looks like a spherical.
2022 1SS 1LE A10 BCD WCT+PDR2014 1SS 1LE NPP RECARO SIM-SOLD1995 Z28 M6 GSC PGM-SOLD1975 NOVA COUPE 300HP 350 TH350 FLASH RED-SOLD
"KEEP THE FAITH"-Fbodfather |
#7 | |
![]() Drives: Chevrolet Camaro Join Date: Mar 2026
WOW. I just ran into this EXACT issue today in my '10 2SS. I need this exact part, so, thank you for including part numbers. A Jeep Liberty, eh? Many of those parts are discontinued, too. But seriously, thanks for the info! I'm ordering 2 bushings right now. |
#8 | |
![]() Drives: 2014 Chevrolet Camaro 2LS Join Date: Mar 2025
I called my local auto parts store that had them in stock, and the employee was pretty sure they weren't spherical, as she couldn't move them with her finger. |
#9 | |
The store employee couldn't move it because it could be very tight when brand new. I have attemped to move new sphericals by grabbing them and I would usually have more success when I would put a long bolt within the inner hole and use the leverage of the bolt length to move the spherical. The photo of the bushing is also odd in the sense that the inner cylinder of the bushing is at an angle compared to the outer body.
#10 | |
#11 | |
![]() Great thread fellas.
