![]() ![]() ![]() ![]() ![]() ![]() Drives: 2014 2SS/RS 6SP Ashen Grey Join Date: Aug 2021
SCT retune w/ HP tuners does car need tobe returned to stock first?
Car currently has a remote tune with SCT, the tuner I will be using for my LSA SC install I am going to request HP ( I believe he uses both ) Do I need to flash back to stock with SCT first? I know this would be a question for him but I don't want to bother him with a ton of questions ( Obviously when i set up appt I will go over all of this ) . I am just wondering and trying to learn.
Thanks
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount. |
![]() Drives: 2013 Chevrolet Camaro ZL1 Join Date: Jun 2025
If you dont flash the car back fo stock, the SCT will be locked and cannot be re-used unless unlocked by SCT themselves. Which is behind a paywall. So either revert back to stock or you'll have an SCT thats useless until you pay the unlock fee (think its like $150-$200). Ask me how I know lol
13' ZL1 Auto: CAI, 95mm TB, Kong Port, 2.55 upper, DSX Aux Pump, ID1050x, Kooks 1-7/8 LT/HF Cats, Corsa Cat-Back, Catch Can, 160 Therm, NGK Plugs, MSD Wires |
Thank you for reminding me of that, I knew it but it did slip my mind. I'll make sure to bring it with me when i go to get set up.
Thanks
