Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Members Area > Ask the Camaro Team
Old 11-26-2025, 06:18 PM   #1
Camaroman9477
Drives: 2018 Camaro 2SS
subframe damage
I went to have an oil change done at NTB when they stopped and noticed that my subframe was cracked pretty bad so they didn't service it. Can anyone tell me what I should do or if the whole subframe needs to be replaced? I'm pretty worried on what needs to happen.
Camaroman9477 is offline   Reply With Quote
Old 11-26-2025, 07:44 PM   #2
Jofu
Drives: 2022 Wild Cherry ZL1 1LE
Hello! Yikes… I personally would go ahead and replace the whole part, as it seems to be meant to help with body/torsion rigidity (i.e. I’d never consider welding that back).
I don’t know how expensive it is new, but you can find some available on eBay for well under $500 shipped. For example:
https://www.ebay.com/itm/38858203176...Bk9SR8K3q6_YZg
I’ve been meaning to replace mine, as I’ve once ran over a pretty big rock that ended up denting it pretty bad, but thankfully in my case the part didn’t give in and, more importantly, it protected everything else behind it.
Geoff
Jofu is offline   Reply With Quote
