Old 11-27-2025, 07:37 PM   #1
Eagleseye
Eagleseye's Avatar
Drives: 2012 Camaro SS vert
Plug wires with headers
Installing 2” long tube headers. 10” or 12 wires with heat shields to insure foo clearance ?
Eagleseye is offline   Reply With Quote
Old 11-28-2025, 10:07 AM   #2
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
I had no problem with stock wires.
0stones0 is offline   Reply With Quote
Old 11-28-2025, 11:42 AM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Stock wire will be fine, unless you want to go aftermarket for any reason, most of use the Taylor 409's on our builds, just to add some color under the hood..
Old 11-28-2025, 06:22 PM   #4
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Stock is fine. I did GM performance wires with fiberglass insulation boots for extra protection.
Old 11-29-2025, 08:01 PM   #5
Eagleseye
Eagleseye's Avatar
Thanks a million! Stock 409 it is in red. I appreciate the wisdom
Old 11-30-2025, 05:51 PM   #6
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yeah the 409's I bought were red to go with my under hood theme. Ya can't see them, but they are there!
Old 12-05-2025, 04:03 AM   #7
TheBrightSide
Drives: 2010 Chevy Camaro 2SS coupe (MT)
What brand 2” LT headers did you go with? I had a friend 5-6+ yrs ago, run the older Speed Engineering ones, and they needed to be dimpled in a bit on both the driver and passenger side primaries.
I once saw someone with Texas Speed ones fit perfectly fine somehow. I think it MAYBE contacted both sides on VERY hard turns on track days and would vibrate/rattle against the steering shaft and frame on the passenger side, in the engine bay.
Had I got 2” inch long tubes though, I probably would’ve just kept the bone stock catback exhaust from my LS3…
TheBrightSide is offline   Reply With Quote
Old 12-06-2025, 10:08 AM   #8
Eagleseye
Eagleseye's Avatar
Speed engineering headers. Used them on my last 2010 with no issues
