Old 12-04-2025, 07:18 PM   #1
cawj87
Drives: 2013 CRT 2SS 6M 1LE
1le 150k miles, engine might be toast, car is rusty, what now?
2013 Camaro 2SS 1le with 150k miles had been running strong up until last week sudden and significant power decrease, dash lights on, running rough, pulled over shut it down right away, had it towed to a shop. Diagnosis is miss fires 6 and 7, swapping coils/plugs didn't help, no compression cylinder 6, scope showing gouging to cylinder wall, likely bad rings I'm told.
Can this be anything other than needing an engine swap or engine rebuild? Head gasket, valve, anything less expensive than an engine?
If it is going to need an engine, am I looking at $7-10k or more?
The car is high mileage and has been my daily for 9 years including snowy salty winters and the car was wrecked and repaired in 2017. There are paint issues including bubbling and flaking with a few spots of visible rust. This became my winter beater so the new car doesn't have to do snow/salt duty.
I figured the value as a whole car was pretty low due to the visible condition and mileage but it ran and drove so I kept with it. I do not think I am looking to put thousands into at this point.
What was my car worth before it broke down? $8-10K? Or less?
What is a rusty Camaro with an LS3 needing a rebuild worth as a whole car? The interior is good and the rest of the driveline, suspension, brakes, etc. were fine.
I am looking at the price of some parts for sale and seeing rebuildable LS3 cores for a couple thousand. It's not like it threw a rod through the block or dropped a valve. It still starts and moves, just rough, no major mechanical noises, knocking, clanging, etc.
I am seeing the Tremec TR6060 used for a few thousand.
1le/ZL1 wheels and tires for a couple thousand. I have new tires on them too.
Are those prices real? Is my rusty broken down car more valuable if I part it out? Parts above plus interior bits, exterior trim, glass, differential, suspension, brakes, etc.
I also have a 63 Chevy C10 with an old 350 and TH400 that maybe someday I would want to swap an LS3 and Tremec into anyways. Thinking of the value of putting the engine/tranny aside and rebuilding them for that down the road and not having to buy them then. I think I would save not buying rebuildable cores or buying newly built stuff if I started with what I have and rebuilt them.
Just not sure where to go from here but would hate to sell the car whole at a huge discount if I could sell parts for more and/or keep some valuable parts for myself.
What would the shell/suspension/brakes be worth if I kept the engine/trans?
cawj87 is offline   Reply With Quote
Old 12-04-2025, 08:13 PM   #2
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
In my opinion it has been neglected & too far gone. Don't throw bad money on bad money at this point. You might get some cash for the 3.91 diff as they are hard to find, but 150k might be a tough sell. Too bad to see a 1LE like this. Maybe other members will have better ideas for you.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 12-04-2025, 10:00 PM   #3
cawj87
Thanks for the input on the differential and advice to not put anything back into it.
It hasn't been neglected, it has been used and thoroughly enjoyed year round. All scheduled maintenance was performed by the book and it was running healthy and strong until all of a sudden it wasn't. Wasn't a steady decline or neglected maintenance, one minute fine, the next not. I hear you on the 1le part. if I had it to do over again, I would have got a regular SS knowing I was going to drive it year round.
Thanks again!
Old 12-05-2025, 04:00 AM   #4
Wizard1183
Wizard1183's Avatar
Drives: ABM SS2/RS M6
Send a message via Yahoo to Wizard1183
Junk yard
Life is short, drive it like you stole it!
Wizard1183 is offline   Reply With Quote
Old 12-05-2025, 06:56 AM   #5
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
The car isnt worth much if you decided to sell and any motor is going to be a more money than the car is probably worth. Figure a clean 5th gen with similar mileage is probably 12-15k. Hell, my car with 85k says it's 18-20.
Salvage yard? Auction? Part it out? Could definitely get a few grand out of parts. Cylinder heads, steering wheel, seats, electronic steering rack, wheels, brakes, diff, axles, sway bars.
Can you PM me. Id be interested in your front splitter since we both have 13s.
Old 12-05-2025, 07:41 AM   #6
FASTFATBOY
Drives: 2013 ZL1
Did the shop do a leak down test?
Did the shop check for a broken valve spring or bent push rod?
Was the car using oil?
I doubt very seriously this car needs a new engine, 150K on a LS is not "high mileage" 300K is.
2015 1SS 1LE, Magnuson 2300 Heartbeat and headers. 550rwhp STD, 535 SAE.
FASTFATBOY is offline   Reply With Quote
Old 12-05-2025, 09:23 AM   #7
detamble13
detamble13's Avatar
Drives: 2011 2SS/RS LS3 VR
As Fastfatboy just said have them check the valve springs. I had the same thing happen to my LS3 years ago and it was a valve spring. One replaced under warranty and when the second one went (out of warranty) I replaced them all. Not crazy expensive. Find a mechanic or dealership you trust and have them diagnose. It sounds like the car is repairable.
I also DD my SS through the winter and have rustproofed it every year. Not sure if you have Krown rustproofing there but I swear by it.
detamble13 is offline   Reply With Quote
Old 12-05-2025, 03:21 PM   #8
acutron42
acutron42's Avatar
Post some pics of your car & see if you can get the bore scope pics. I would also get a 2nd opinion.
Old 12-06-2025, 06:31 AM   #9
70T/A400
Drives: 2013 Chevrolet Camaro ZL1
You should look into a leak down and compression test on all cylinders. That will tell you the health of the engine. The LS lifters have known issues with the check valves.
70T/A400 is offline   Reply With Quote
Old 12-06-2025, 08:42 PM   #10
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
You can tear it down, get it rebuilt, and add speed parts for under $5k.
Long live 5th gens
joshnmn is offline   Reply With Quote
Old 12-07-2025, 08:11 AM   #11
FASTFATBOY
Drives: 2013 ZL1
Long live 5th gens
On what planet?
Maybe 10 years ago doing the labor yourself.
Old 12-08-2025, 05:38 AM   #12
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Down here LS3 cores are maybe a grand, diff is worth a grand, but it's high mileage and anybody looking to swap to a 3.91 probably wants to beat on it. I see TR6060s all the time for $1500. The 1LE is a more rare unit with different gearing, but given the mileage, you are probably not going to get much more than that.
It is probably worth the most to someone who wants to build a 1E, but you are years away from that being common thing.
If you turned your own wrenches, it would be worth pulling and rebuilding, but I assume you pay to get your cars worked on. However, that begs the question of who is dissambling it for the part out?
Old 12-08-2025, 11:56 AM   #13
Mhoelzel
Drives: Chevy Corvette Z06
Just how rusty is rusty? Like holes in sub frames?
Mhoelzel is offline   Reply With Quote
Old 12-09-2025, 08:21 PM   #14
myold88
myold88's Avatar
Move on !
