Old 12-08-2025, 05:46 PM   #1
Jrowland95
Jrowland95's Avatar
Drives: 2014 camaro ss l99
14 SS Driver side Axle Play
I’ve been having an issue for a while where I was blowing through driver side axles. It’s a stock L99 with a tune, so it’s not too much car for the axles. Anyway, I noticed the driver side Axle had a bit of up and down play @the diff where the passenger side is completely stiff. This weekend I tore the diff apart and changed the carrier bearings, finally reassembled today and have pretty much the same amount of up and down play. Has anyone had this issue? Does the carrier need to be replaced? Everything looked great when it was apart; slight slight pitting on the spider gears. Pinion was tight no noise or play when spinning it. Ring gear looked great. Trying to upload a video from my phone, I’d say it’s 1/8” total up and down play in the axle. Also the last axle I pulled out of the driver side had obviously gotten pretty hot so I’m just trying to figure out if the play is normal and the bearing was killing my axles or if I should be expecting the new axle to give out sooner than later and just need to do additional repairs/replacement.
Jrowland95 is offline   Reply With Quote
Old 12-08-2025, 05:57 PM   #2
Jrowland95
Jrowland95's Avatar
https://youtu.be/tUWMJjalWJA?si=Uy6b4eEtD3O1Gi-w
That’s the video. Also the metal clanging noise is not the axle or the rear end 😂. I’m not sure what I was tapping on but the axle movement is pretty quiet. The movement up and down also isn’t enough to create a leak if that matters.
Old 12-10-2025, 05:59 AM   #3
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
If the caps are good, which I would think you would have noticed if they were bad when you changed bearings, it sounds like the carrier. You could pull the axle and see if you can get the splined receptacle to move around. Maybe you can see what is going on without pulling it all apart.
Old 12-10-2025, 10:45 AM   #4
Jrowland95
Jrowland95's Avatar
I'll have to pull the axle this weekend. I'm assuming it's the carrier. When i tore the diff apart I checked to see if there was a ton of backlash between the ring and pinion and it felt pretty good. I should have put a gauge on it and measured it while it was apart, but I say that to say, when I did finally get the axles back into the car, I was able to rotate the axle/wheel a decent bit. Definitely was able to rotate forward and backward farther than just the pinion backlash, so I'm assuming most of that play is coming from the LSD.
