![]() Drives: 1977 camaro Lt Join Date: Dec 2025
One front tire sticks out further than the other
I have a 77 camaro stock 305 Lt with ac . Just put new 225 60 15 tires all the way around.. Left front tire rubs when hitting bumps now.. It looks like the Left tire sits out further from the wheel well than the right. It had 215 60 15 on front and 235 60 15 on back with no problems... could it be too much positive camber tilting it out and alignment might fix problem
![]() Drives: 2011 Camaro 2SS/RS Join Date: Jul 2021
Yes. That's probably it.
![]() ![]() Drives: 2014 1SS/1LE Join Date: Nov 2015
Different wheel width or offset front to rear? Could have a rear wheel on the front.
Sent from my Pixel 8 Pro using Tapatalk
