Old 12-10-2025, 08:52 PM   #1
LS3Kook
Drives: 2014 Camaro 2SS RS 1LE
Engine Rebuild
Long story short, I had a valve seat drop and cracked a piston and put a hole in my head. Now I'm trying to decide the next steps.
I have a build in mind but asking for recommendations, definitely don't have a unlimited budget but I'm willing to spend around 5k or a little more on the build not including dyno/tune. Currently I have a tsp stage 3 NA Cam with ls7 lifters, kook headers and a couple other minor things (installed around 15-20k miles ago).
I'm currently looking at the TSP H-Beam Rod and JE LS3 No-Balance Piston Combo - No Balance w/ LS3 Crank with Brawler LS3 Style CNC Ported Cylinder Heads w/ TSP .660" Spring Kit and Titanium Retainers. Has anyone used either the heads and or piston/rod drop in set. I know it says no balance required but just seeing if anyone has run into any issues with them.
I also plan on eventually boosting the vehicle haven't decided between turbo, pro or supercharger yet but I'm thinking of going with the Cleetus McFarland "Bald Eagle" LS3 Boost Cam just because I can run it NA until I can boost it in the future
Also plan on getting bigger injectors Aswell intake/throttle body, currently looking at the fast lsxr intake
Honestly just putting this out there to see if anyone has any recommendations for the build or if I should take it in another direction. Appreciate any input
LS3Kook is offline   Reply With Quote
Old 12-11-2025, 03:59 AM   #2
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
So the motor really isnt in that bad of shape and the damage is purely to the piston and head? Theres no major scoring to the cylinder wall? No cracked skirts or anything?
Id trust Texas speed they'll stand behind their product.
Skip the FAST intake manifold. BTR Trinity is showing better results on LS7s than a ported MSD. Bang for buck go with a GPI rod mod intake. Power is basically the same between a rod mod and a FAST at a fraction of the price.
Old 12-11-2025, 06:49 AM   #3
FASTFATBOY
Drives: 2013 ZL1
How many miles are on it?
Is the cylinder wall or rod damaged?
2015 1SS 1LE, Magnuson 2300 Heartbeat and headers. 550rwhp STD, 535 SAE.
FASTFATBOY is offline   Reply With Quote
Old 12-11-2025, 07:54 AM   #4
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
So, was this dropped valve on a DD just tooling to and from work or do you beat on this car? Just curious how "bulletproof" this LS engines really are? Hanging around here for 12+ years, that hardly sems the case...sometimes.
Moto-Mojo is offline   Reply With Quote
Old 12-11-2025, 09:45 AM   #5
LS3Kook
As far as I can see no scoring or cylinder wall damage, I plan on putting in new pistons and rods all around. Vehicle has right around 120k on it, definitely not babying the car but not tracking it every weekend.
Have kept the car well maintained since purchasing it 5 years ago, has had no major issues prior. The valve seat dropped on start up, have seen its a common issue with overheating but the vehicle has had no signs of overheating.
build advice, engine internals
