Old 12-14-2025, 03:28 PM   #1
Mach-1
Drives: 2015 Camaro ZL1
LSA Engine Cover
Hello all,
Newly acquired ZL1. I noticed that the silver "SUPERCHARGED" and "LSA" lettering has faded off off the engine cover and gone to red.
Anyone seen this before? Any tips or ideas on how to restore it to original look? I searched the forums and came up empty.
Mach-1 is offline   Reply With Quote
Old 12-14-2025, 04:43 PM   #2
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
mines the same way. just toss it in the basement, it just holds heat in.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 12-14-2025, 06:13 PM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^ Yep, this.. But if you want to "color" them, you could put some painters tape over them, cut out the lettering with a sharp x-acto knife, then tape off the rest of the cover so you don't get any paint on it, and paint away!!
Old 12-14-2025, 08:41 PM   #4
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
They all fade away eventually. Same with the Z/28 engine covers. You can buy custom ones that are pretty cool or just do what the others have said. Take it off and forget it.
Old 12-15-2025, 06:58 AM   #5
Mach-1
Thanks! Good to know that mine is not the only one!!
Joe
