Old 12-29-2025, 11:46 AM   #1
kpeters59
Drives: Black 2012 SS Convertible
Cooling fans troubleshooting help, please!
Hey all!
I have a 2012 SS that the cooling fans don't seem to turn on as commanded every time.
I've been fussing with this for a bit and only recently learned that I can command them on with my MPVI3.
When I do that, it turns them on sometimes. Most times, really.
But, there has been multiple times when I command 'Fan 1' on, which is 'Low Speed' for both fans, they either won't turn on at all, or they might kick on briefly, but then shut off.
This also happens, usually at the same time, that Fan 2, which IIRC, is the Drivers Side Fan and Fan 3 also don't go in to high speed.
When it's working, if I only command Fan 3 on it will go to High Speed and Fan 2 will go on if I command Fan1&2 together.
During this mornings poking around, I did notice that Fan 1 did seem to respond to some gentle wiggling, which surprised me because I'd tried that multiple time previously without seeing that. Because Fan 3 ought to be able to work in High Speed regardless of Fans 1&2.
I pried the covers off of the relays and while manually pressing the relay all 3 modes work every single time.
I visually inspected the relay sockets and the fan 4-pin plug. They look very good.
I'd guess that I need to locate some 'test points' for the harness wiring.
Can anybody help me figure out how to determine which pin on which plug at the PCM and the fuse block I might be able to get to to manually test at?
I do have a fake Power Probe that I ought to be able to inject the correct signal to the circuit. It looks to me like the PCM pulls the relay coils to Ground, right?
Anyway, sorry for the long post, but I figured we could skip ahead a bit if I posted what I'd already tried from a few other threads on this forum.
TIA,
-KP
kpeters59 is offline   Reply With Quote
Old 12-30-2025, 08:31 AM   #2
gtstorey
You can get full wiring diagrams from;
https://www.acdelcotds.com/subscriptions
Old 12-30-2025, 08:33 AM   #3
gtstorey
And you sometimes have to be careful using HPT's commanded stuff. It occasionally doesn't behave like you think it should. I don't know if this is one of those cases.
Old 12-30-2025, 11:21 AM   #4
gtstorey
Originally Posted by kpeters59 View Post
Thanks for replying!
I seem to have wiring diagrams, but it's unclear which plug on the PCM and Fuse Block is which.
[IMG]file:///E:/Downloads/attachment[1].php.jpg[/IMG]
Attachment doesn't show but the ecm connection location diagram and pin out should be available at the ACDELCO TDS link.
Old 12-30-2025, 11:35 AM   #5
kpeters59
I was having trouble getting photos inserted.
So which harness at the PCM would have the fan wires?
And which one at the fuse block?
Thanks!
-KP
Old 12-30-2025, 12:17 PM   #6
kpeters59
Ok, I found this on LT1swap:
Engine Control Module X1 (L99 or LS3) BLACK CONNECTOR, 73 PIN, 2010 CAMARO
Engine Control Module X2 (L99 or LS3) GRAY CONNECTOR, BLACK COVER, 80 PIN
https://lt1swap.com/2010camaro_ecm_pinouts.htm
Dang, it's like secret information...
-KP
Old 12-30-2025, 12:20 PM   #7
gtstorey
-KP
Not secret, just not easy for free. $22 would get you access to all the service manual information for 3 days. Download all the wiring diagrams, pinouts and connector information.
Old 12-30-2025, 12:46 PM   #8
kpeters59
I have that information.
What wasn't easy to locate was the identification of which plug was which.
Even LT1swap's information was hardly discoverable with just a single line of information.
I'll figure out which pin on which plug is for the fan relays and go from there.
My expectation is that it's most likely in the PCM to Relay connection.
I wouldn't expect the PCM is only sometimes getting the relay coil pulled to ground. Unless it's a grounding issue at the PCM?
How can I get to the underside of the fuse block, if the issue is there? I also haven't located much information on that.
Thanks,
-KP
Edit:
I also found this:
PCM located on passenger side in engine bay.
"X1" (black) is toward the front of the vehicle on the PCM.
"X2" (gray) is toward the rear of the vehicle on the PCM.
You can only see the colors (blk and gray) once the connectors are disconnected.
Here:
https://www.camaro5.com/forums/showthread.php?t=48639
Old 12-30-2025, 01:48 PM   #9
gtstorey
The oem service manual will show exactly which connector is which in relation to the call outs on the oem wiring diagrams. If you are looking at that as a source, you aren't finding the correct pages.
Old 01-01-2026, 01:54 PM   #10
kpeters59
Thanks!
So X1 is not the black PCM connector like in the image I posted above?
And X2 is not the gray connector at the PCM?
-KP
Old 01-02-2026, 08:42 AM   #11
gtstorey
I think what acutron42 posted is a fusebox connector, not the ecm. It actually says fuse block on the second image.
Old 01-02-2026, 09:56 AM   #12
kpeters59
I get that.
It's just that the documentation I have calls X1 the Black PCM connector and X2 the Grey PCM connector.
I thought X3 was the Fuse Box connector.
.-KP
Old 01-02-2026, 11:35 AM   #13
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
Good observation GT, I will see if I can find the Bosch connector info.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 01-02-2026, 11:48 AM   #14
acutron42
acutron42's Avatar
My bad, I uploaded the wrong pics. I deleted that post & here is the Bosch K20 X1 info.
