Old 01-04-2026, 12:32 AM   #1
Benji
Drives: 2011 Camaro LS
Better Injectors
Hello, this is my first post so nice to meet you all. I've been putting together some mods I'd like to do to my 2011 V6, and while I have been able to find most things, I'm stumped at finding either new, better injectors or a place that can upgrade my stock ones. Does anyone have any recommendations? And don't say buy or swap a v8.
Benji is offline   Reply With Quote
Old 01-07-2026, 07:05 AM   #2
KillboyPowerhead
Drives: 2015 Z/22
Any particular reason you're changing the injectors?
KillboyPowerhead is offline   Reply With Quote
Old 01-18-2026, 12:36 AM   #3
Benji
I'm not at the moment. Just looking for ideas for when or if I boost further down the line
Old 01-18-2026, 11:10 AM   #4
KillboyPowerhead
Drives: 2015 Z/22
I believe the LLT factory injectors are good for 8 - 10 lbs at which point the factory high pressure fuel pump is maxed out, and don't believe there is any known replacement that works with the factory ECU. Not sure how many boosted LLT owners still frequent this board; Tracy Lewis may be able to help too (https://tracylewisperformance.com/co...charger-system)
