Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro Motorsports Discussions
Old 01-08-2026, 07:05 PM   #1
SSFury
My Road Rage is Legendary
SSFury's Avatar
Drives: 2011 IOM 2SS/RS "Fury"
Small Tire
My local track is holding a 3-day event coming up mid Feb. I've been to the track once. Looking to get into this one. Im still N/A. Running about 500 HP. I don't have the power to get into the “Better” classes. Im running Nitto NT 555R2’s on the back. 315/35/20.
The class is “Small Tire” only. 28x10.5. I apologize for my ignorance, but I’m new to this. My tires are 35 sidewall. 35>28. Does that disqualify me for this class? Wanna make sure I’m in the right class. Thank You for any help. Much appreciated.
PHP Code:
[SPECIAL][/SPECIAL
Every Time You Buckle Up In That Car, Tonight Might Be The Night That You Die.
SSFury is offline   Reply With Quote
Old 01-08-2026, 09:06 PM   #2
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
28" is the overall height of the tire. not side wall. your tire is a 28.4"x12.5" so you probably need a different tire.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 01-08-2026, 09:08 PM   #3
tartagliazl1
i have a question? did you beat that SRT4? when i was in my early 20's i had a built engine turbo, nitrous 98 neon coupe. car was fun. 12lb boost for 280 whp.
Old 01-09-2026, 09:50 AM   #4
SSFury
SSFury's Avatar
Sadly, I did not. Although in my defense I was running extremely bald Continental Extreme Contacts, and it was my first ever time at the track. Never having experienced it before, I thought "I'm at a track, that's what tracks do." So I floored it. And sat there spinning. I was reeling him in good by the end, but the damage was done. My record is a whopping 0-1. That's when I bought the Nitto's, and said: Next time will be different. lol.
Old 01-09-2026, 09:53 AM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Here's some cool info for you, the only thing it mentions for "small tire" is the tire diameter. Also the tread size can't be any wider than 10.5, which is the size of a standard 275 DR.. your 315's will be too wide. Good luck, and have fun!!
https://carsbibles.com/what-is-small-tire-drag-racing/
Old 01-09-2026, 11:34 AM   #6
SSFury
SSFury's Avatar
Thanks. Appreciate it.
