Old 01-14-2026, 04:56 PM   #1
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
What are everyones thoughts on BTR Stage 3 PDS torque cam, 1st version?
Hi,
I I am still trying to narrow down what cam to use, I have a Brand new BTR Stage 3 PDS Torque cam ( not their Newer V2 but their older one ) which is brand new. Would this be a good cam? How do you guys think it compares to a GPI Stage 2 or Jannety Racing's offering?
I want a nice driver, I don't want a cam that is not fun to drive on the street.
LS3, Ported LSA Blower 3.91 Gears Supporting mods for cam and LSA SC and the rest of the stuff in my sig below.
I have not really read anything bad about the Older BTR Cam I have here.
https://gwatneyperformance.com/gpi-l...ower-camshaft/
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 01-14-2026, 05:15 PM   #2
divine_godly
divine_godly's Avatar
Drives: 2013 Chevrolet Camaro ZL1
Thats a pretty aggressive cam for the street. Are you also doing a high stall torque convertor? If not then it's not gonna be a nice drive at all on the street. Also remember with high stall convertors, you will also need a trans cooler
13' ZL1 Auto: CAI, 95mm TB, Kong Port, 2.55 upper, DSX Aux Pump, ID1050x, Kooks 1-7/8 LT/HF Cats, Corsa Cat-Back, Catch Can, 160 Therm, NGK Plugs, MSD Wires
divine_godly is offline   Reply With Quote
Old 01-14-2026, 05:21 PM   #3
Bluebagger06
Bluebagger06's Avatar
Drives: 2012 camaro ss
Send a message to Andrew Cammer {GPI} on here , He can help you out
GPI Powered
Bluebagger06 is offline   Reply With Quote
Old 01-14-2026, 05:43 PM   #4
Joe.G
Joe.G's Avatar
I am manual, Everything I am reading about this cam people seem to talk highly of it.
Old 01-14-2026, 05:58 PM   #5
divine_godly
Scratch what I said then. People love BTR cams and you won't regret it! If it was auto I'd say it would be pretty aggressive for the street lol
Old 01-14-2026, 06:00 PM   #6
Joe.G
Joe.G's Avatar
So in a manual your opinion this is a decent cam to run in my build? I want the package to work well together.
Old 01-14-2026, 06:13 PM   #7
divine_godly
I believe so! Hoping someone with a manual and a similar cam to what you have will chime in and give you a better opinion on street drivability since I have an auto.
Old 01-14-2026, 06:32 PM   #8
Joe.G
Joe.G's Avatar
What cam are you running?
Old 01-14-2026, 07:40 PM   #9
divine_godly
Installing a BTR Stage 1 PDS V2 Cam right now actually. Can't speak on drivability as i haven't driven it just yet. I went stage 1 as it works the best with the stock convertor and she's mostly street driven
Old 01-14-2026, 08:06 PM   #10
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
joe. shoot mark (fasnuf) a message. He was running the same cam in his zl1. Never heard him say anything bad about it. He's moved on to a c8 now, but he stops in from time to time.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 01-14-2026, 08:20 PM   #11
Joe.G
Joe.G's Avatar
I will, I remember watching his You tube video, I forgot that he used the Cam I'll have to check to see which version it was.
Old 01-14-2026, 09:17 PM   #12
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
You being a manual car, you can get away with having a larger cam and it being streetable and easy to drive. Its a pd blower cam so its exactly what you're build is going to be. Then the most important part of driveability for any round of modification is tuning. Tuning can literally make or break a car especially a cammed car.
Old 01-14-2026, 09:24 PM   #13
Joe.G
Joe.G's Avatar
Yes I understand the tuning part, I just want to make sure I choose a cam that fits my goals and blends well.
Old 01-15-2026, 07:14 AM   #14
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
Pretty sure that's the same cam I'm running and it's fine on the street with a manual transmission. I daily drove it for a couple of years but I didn't sit in heavy traffic either.
Sent from my Pixel 8 Pro using Tapatalk
