Old 01-15-2026, 06:39 PM   #1
rmaringa
Drives: 2012 Black Camaro
Exclamation Relays checked, battery checked, fuses checked, new alternator, new compressor
New compressor and new alternator. Relays and battery and fuses checked. New blower motor resistor. New condenser. I checked all my fuses with a multimeter and my relays with an automotive relay tester.
Compressor still won't come on.
40amp fuse just causes air to blow. I unplug it and it stops. I don't feel any coldness on the touch of the HVAC pipes under the hood.
I can't activate my AC switch on my Scan Tool either.
Now also in addition to my HVAC, my 2 radiator fans won't turn on either.
Why? How do I fix?
rmaringa is offline   Reply With Quote
Old 01-15-2026, 08:02 PM   #2
xstuntman
Drives: 2012 Victory Red LFX
BCM?
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
xstuntman is offline   Reply With Quote
Old 01-15-2026, 08:21 PM   #3
rmaringa
Originally Posted by xstuntman View Post
BCM?
Do you know if the radiator fans go thru the BCM or HVAC module?
Old 01-16-2026, 10:35 AM   #4
xstuntman
Not sure on the radiator fans.
The BCM does on the HVAC.
Two separate problems?
This might be the one time it would pay to let the mechanics look at instead of throwing more money at it.
Old 01-16-2026, 01:16 PM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^ This. Their scan tools can go deeper than most "outside" scanners to see whats up. Good luck.
cooling, electrical, hvac, radiator
