![]() Drives: 2011 Camaro 2SS/RS Join Date: Jul 2021
Forward thinking on parts
In short, I don't like doing things twice, so I'm trying to be thoughtful with everything I do to this car. Right now the motor is stock other than long tubes, CAI, and tune. Eventually, It'll probably be a heads/cam kind of build, then blown. That's possible long term progression. But for the moment, I'm just looking at exhaust. Have been debating Corsa sport. vs Xtreme. First debate is if Xtreme is gonna be too loud. I know, subjective. But I've also noticed the. Xtreme setup is a 3" pipe and the Sport is a 2.5" pipe. That's where my question comes in.
When the motor gets built up, will I see that much performance difference between 2.5 and 3? I doubt I'll ever invest enough to get beyond 500-550whp. So, not sure how much diff it'll make. And if I do end up with 3" pipes, I'm gonna want to cut off the step down on the cats to have 3" all the way. |
![]() ![]() Drives: 2014 1SS/1LE Join Date: Nov 2015
FWIW, I felt my car had the best sound and volume at headers, hi flow cats, and then the stock 2.5" NPP.
When I decided to go blown, I ditched the hi flow cats and after a few iterations trying to get a sound I liked, I ended up with a cobbled together 3" through an x-pipe all the way back until it sleeves back down to 2.5" right before the NPP mufflers. It's not perfect and it's pretty obnoxious at WFO, but I can still manually close the NPP flaps to tone it down when I want to. Sent from my Pixel 8 Pro using Tapatalk
![]() ![]() ![]() Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
For me, I already had the Borla Type S which is a 2.5" kit. My setup is rather tame sounding with this exhaust.
I did a pair of 3" QTP low profile cutouts about 2' past the turbos (right in the bend before turning in. Everything past the cutout is the Borla Type S as designed. My cutouts are operated with the garage door opener, 1 button to open, one button to close. I have neighbor friendly exhaust and Wild and radical sound at the push of a button. I would go with the Sport kit and use cutouts for max sound and performance. Brian
#4 | |
Fast Cars and Old Guitars
Drives: 2015 2SS RS (L99, baby!) Join Date: Apr 2012
I have on my Camaro the Corsa ZL1 Sport catback, and it is 3" all the way from the headers back, no cats, just an off road connection at the headers. 1 7/8 SP LT's. It is very loud at idle, and WOT. The sport mufflers and a bit bigger/longer than the Extreme mufflers if you look at them. Plus the ZL1 system is a quad setup, vs the Extreme is a single tip. If I want it louder I have like slow's system, the QTP low profile cutouts located the same place as his, except mine are turned towards the outside of the car, where his are turned inwards. The Corsa system is the only setup I have had on the car that actually has ZERO drone at cruising speeds. Pretty quiet until you romp on it!
#6 | |
#7 | |
#8 |
![]() Drives: 2012 camaro ss Join Date: Sep 2018
Mine kind of similar to JEWLD's, I went with 17/8 LT's, with 3 inch Retro chambered catback by stainless works , No cats or resonators and it barks when you stomp on it but its great at cruising speeds , no drone at all!
GPI Powered
#9 | |
It's not as loud as you would expect, the turbos do a good job of muffling the sounds and just make whistles instead.
#10 |
Tri-County Camaro SWFL
I loved my NA setup. SP 1 7/8 longtubes, no cats into factory NPP catback. Was pretty loud at idle and WOT but still had the availability to close valves. Had minimal drone with valves open and no drone valves closed. Still run the factory NPP.
I wouldn't be afraid of running the 2.5in Corsa sport. Extremes with longtubes is LOUD but sounds great. Food for thought my car FBO made 462whp. Heads cam made 513whp. Now makes a hair over 800whp all through the factory NPP catback thats 2.5in.
#11 |
Yeah one of my buds that has a ZL1 has the Stainless Works system you have, and LT's, and yes it sounds pretty good! He loves it, I almost went with that one too.
#12 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
I also have the GFX on my car. I simply ordered the Corsa Xtreme kit that was made for GFX cars, comes with no tips. Corsa are one of the few companies that makes exhaust for GFX owners. All of my other exhaust setups, I had to hack the tips off of brand new kits, which sucked of course.
#13 |
A legend in his own mind
Drives: 2010 2SS/RS M6 Join Date: May 2013
I have the GM GFX kit on mine. I have LT's, Catless connections, and the 3" Corsa Xtreme. The GFX version comes with no tips, fits perfect in the GFX. Sometimes I wish there was a tip on it but mostly it looks fine. sounds great. Before the Corsa, i had the Borla and i loved that too but the Corsa is badass
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's / MRR 228 Wheels / BMR Springs / Koni Yellows / R1 Concepts Rotors & Pads 2006 Dodge Magnum RT "The daily" |
#14 | |
I am trying to source black ones and only tyhe left one is available, so I may be flipping one to make it work. These tips were designed for the GFX kit and are the right size and have the correct bevel manufactured in to them so thatt they will look right. MBRP Rectangular, Polished 3 Inch Exhaust Tip T5120 https://shorturl.at/XXFWR $49.95 each
2011 2SS/RS Convertible, Victory Red, Roto-Fab CAI, Stainless Power 1 7/8 headers, No Cats, Straight piped, Bo White TB, Circle D, 3.91, ZL1 CONVERSION, CDC Roll bar and some powder coating and dipping.
