Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics > ZL1 Wheels/Tires
Old 01-19-2026, 05:04 AM   #1
divine_godly
divine_godly's Avatar
Drives: 2013 Chevrolet Camaro ZL1
Which 17" Inch wheels fit with no issues?
Hey Guys! I have a 2013 ZL1 on stock height, stock suspension and stock brakes. I am approaching the power level where I'll need some meat out back to hook on the street. I would like to know what 17inch wheels (and what specs) fit our cars without ANY modification such as trimming down bolts/brakes? I'm fine with tying back the brake line. Going for non-beadlock and enough space so the wheel weights wont be kocked by the caliper or something (a balanced wheel is a happy wheel lol.)
I spoke directly with weld wheels and they told me that any of their 17x10 et 42 wheels will fit without any modification. Can anyone confirm if this is true?
Hoping to fit a 305/45r17 tire back there. Not the focus of this post but tire recommendations are welcome !
If there are truly no 17inch wheels that fit without modification then I'll probably end up going with an 18x10 weld wheel with a 305/40r18 or 315/40r18 tire...
13' ZL1 Auto: CAI, 95mm TB, Kong Port, 2.55 upper, DSX Aux Pump, ID1050x, Kooks 1-7/8 LT/HF Cats, Corsa Cat-Back, Catch Can, 160 Therm, NGK Plugs, MSD Wires
divine_godly is offline   Reply With Quote
Old 01-19-2026, 07:28 AM   #2
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
weld, vms, racestar all fit without much mods. You may have to tie the brake cable back. I have a set of black 18" racestars with brand new tires for sale, if you are interested and on the eastcoast. i weighted them with nitto 555r11 on each, the stock zl1 5 spoke and tire weight 61.8lb with a 305 and the racestar with same tire but a 315 weighted in at 54.4lb
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
