Old 02-11-2026, 08:24 AM   #1
Seebers
Drives: 2011 Camaro SS
2011 SS No Sound / Audio
Hey all,
New owner of a '11 2SS with less than 20K miles. The car sat for sometime and the previous owner is not much help on it's current electrical gremlins.
One of the issues is with the radio - it lights up and all switches/buttons work however I have zero sound (including door chimes which I understand run through the radio).
I've checked the wiring on the AMP and I'm getting 12V on B+, ground has zero resistence and Remote Enable is showing 12V when key is turned to ACC/ON. Before I have an amp shipped, is there anything else I could be missing?
Thanks,
Seebers is offline   Reply With Quote
Old 02-11-2026, 10:46 AM   #2
MR.Sarge
MR.Sarge's Avatar
Drives: 2015 2SS/RS CRT 1LE
I'd start easy and look at fuses personally to start
MR.Sarge is offline   Reply With Quote
Old 02-11-2026, 05:46 PM   #3
Seebers
Figured it out - replaced the AMP and all is well. After taking the old one apart, it looks like water got into it.
Old 02-12-2026, 07:47 AM   #4
BBQdDude
BBQdDude's Avatar
Drives: 2010 Chevy Camaro 2SS RS
Was the amp in the trunk?
If so I would suggest taking a hard look at the fuse block in the trunk for water damage.
BBQdDude is offline   Reply With Quote
