Old 02-11-2026, 08:21 PM   #1
Desert_Rob
Drives: 2010 SS Camaro
what's your favorite lift or jack ?
pretty new to the Camaro, would like to know what is best to get for oil changes, transmission swap, motor lift, and pictures of your setups would be cool
Desert_Rob is offline   Reply With Quote
Old 02-11-2026, 08:51 PM   #2
SS_Dave
SS_Dave's Avatar
Drives: 2011 Camaro 2SS/RS
I use a set of QuickJacks. They have been great for all of my vehicles. Used them to pull the rear cradle for suspension mods and other stuff. I leave them under the wife's Jeep for storage since my Camaro and Cadi are too low to drive over them. Only thing I'd rather have is a full four post lift, but that just hasn't made it up the spending priorities yet.
SS_Dave is online now   Reply With Quote
Old 02-12-2026, 06:01 AM   #3
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
Quick jacks are nice. Friend let me borrow them for my twin turbo install. Did it in my garage with those.
CamaroDreams76 is online now   Reply With Quote
Old 02-12-2026, 06:21 AM   #4
SlowLS1
SlowLS1's Avatar
Quick Jacks are great once you get past the fact that there is no side access. Have to go in and back out at the front or rear of the car.
100% would buy again. Much quicker that jack stands and having 2 different works heights is very nice.
SlowLS1 is online now   Reply With Quote
Old 02-12-2026, 07:01 AM   #5
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Depends on what you have to work with. I just put in a used 7k two post and it works pretty well. I had to switch to a wall mount garage door opener, but it lifts high enough for me to stand under it and work. The one disappointment is my car is about a quarter inch too low in front to be to swing the front arm into position without putting floor jack under it to swing the arm into place. I lift with each arm under jack pads listed below. Also need 220v for it. I put a 20ft extension cord on it and added an outlet off the compressor outlet.
Some things that will make your life easier are jack pads like these off Amazon. I'm not sure if ZL1 Options still sells them, but these work about the same. I have these on the vert and ZL1 Options on the turbo car.
https://www.amazon.com/dp/B077PLTRF3?ref_=ppx_hzsearch_conn_dt_b_fed_asin_ti tle_2"]https://www.amazon.com/dp/B077PLTRF3?ref_=ppx_hzsearch_conn_dt_b_fed_asin_ti tle_2"]https://www.amazon.com/dp/B077PLTRF3?ref_=ppx_hzsearch_conn_dt_b_fed_asin_ti tle_2
A good long reach, low profile jack is worth the expense. A smaller 1.5 ton race jack also comes in handy. I used the small jack to lift the side a few inches so I can get the long reach in place. I've been using jackstands to do lots of mods since I bought the car in 2009.
Old 02-12-2026, 07:14 AM   #6
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
I like the quick jacks, I think if I had to do it over again I would order the longer ones and skip having to use the extensions, which add height,weight and extra stuff to mess with.
Camaro Cracka how tall are ceilings in photo?
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 02-12-2026, 07:03 PM   #7
Desert_Rob
Thanks for the wealth of information guys, this helps me a lot. Sure glad to have joined this forum
Old 02-13-2026, 08:53 AM   #8
hesster
hesster's Avatar
Drives: '10 T/A Conv, '10 2SS, '77 SE T/A
Invaluable for serious under side work - and most importantly - safe if you need the car up higher than standard jack stands.
hesster is online now   Reply With Quote
Old 02-13-2026, 02:07 PM   #9
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Race Ramps. The extended ones, for easy front end clearance .
0stones0 is offline   Reply With Quote
Old 02-17-2026, 05:50 PM   #10
Desert_Rob
extended quick jack it is. I have a set of race ramps for maintenance but want to be ready when working on it. Thanks to everyone, this will be easy now. does the quick jack have a safety locking pin, I haven't looked at that area.
Old 02-18-2026, 06:16 AM   #11
SlowLS1
SlowLS1's Avatar
QuickJack makes one large enough to use without the extension kit. It's the one I have but not sure of the model. I can find out if you need.
There is a latch that it rests on, no safety pin. I always put a jackstand under the back so that if the latch broke, it would fall on the jackstand.
Old 02-27-2026, 08:58 AM   #12
Desert_Rob
Thanks. Great looking picture of your car
