Good Times Rollin'
Ambient Temp Sensor Location?
Removed front bumper fascia over weekend, to replace headlight assemblies. Found this little device hanging loose, not snapped in place anywhere. I think it is ambient temperature sensor? Does anyone know where this is supposed to snap into place?
Just gettin' started...
![]() Monster S Twin clutch, CAI intake + Phastek scoop, Elite Engineering catch can, BMR toe rods/trailing arms, Katech TB |
Wifey Lover
Drives: 2013 2LT to 2SS Manual Conversion Join Date: Nov 2011
If memory serves it's mounted to the middle support bar below the hood latch. Been a while since my conversion and things are murky in this old gourd lol. Good luck
2013 2LT to 2SS Manual Conversion |
Good Times Rollin'
Thank you! I will look there. Sweet looking ride!
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
You can see the connector in the bottom left. You will have to remove the front fascia to get to it though. |
![]() ![]() ![]() Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
Standing in front of the car with bumper cover removed, it's mounted in the vertical radiator support on passenger side.
#6 |
Good Times Rollin'
I see the sensor in pic, thank you! More concerning, it looks like they did not give me back all these plastic panels (deflectors?) in the rebuild. Anyone know if these are available still, OEM or aftermarket?
#7 |
Good Times Rollin'
Once I figured out what these parts were actually called, I was able to find OEM units at GM Parts online. Images below, in case someone else needs this one day.
#8 |
I don't know what purpose they actually serve but I know the air damn on the bottom you can do without. All it does is better direct the air flow to the radiator.
#9 |
Good Times Rollin'
I decided to get all the missing plastic pieces, just makes me feel better to have her back to intended factory setup. I was able to properly mount the little air temp sensor also, so that is nice! I was noticing that the lower air grille is quite large, wondering how much radiator airflow relies on that lower opening? Also, the lower deflector sits on top of some fairly stout steel supports... is it possible there is a bit of downforce benefit to that deflector, in addition to channeling air to radiator? This is probably how rumors get started... sorry all!
![]() Here's some pics of added parts...
