Old 02-21-2026, 11:30 PM   #1
Mat28
Drives: 2014 Chevrolet Camaro 2LS
Question V6 to Z/28 Suspension Swap
I have a 2014 2LS with just under 140K mi, I'm up to date on mechanical maintenance so I think it's time to refresh the suspension.
It's my daily driver, but I want to make it handle better, and be more fun on a back road.
So far I've ordered:
Z/28 Rear Trailing Arms (92246140)
Z/28 Rear Toe Links (22845487)
Z/28 Rear Right Upper Arm (23110246)
Z/28 Rear Left Upper Arm (23110245)
Z/28 Front Left Upper Arm (20951300)
Z/28 Front Right Upper Arm (20951301)
Z/28 Front Left Radius Rod (92236899)
Z/28 Front Right Radius Rod (92236898)
Z/28 Rear Sway bar End Links (22761221)
Z/28 SKF Front Wheels Hubs (BR930555)
FE2 Front Left Shock (506946)
FE2 Front Right Shock (506947)
FE2 Rear Shocks (560691)
FE2 Bump Stops (92195502)
Front Shock Mounts (22843712)
Rear Left Shock Mount (V510088)
Rear Right Shock Mount (V510089)
SKF Rear Wheel Hubs (BR930674)
I plan on ordering:
Detroit Speed Front Sway Bar (031412DS)
Detroit Speed Rear Sway Bar (042215DS)
Detroit Speed Front End Links (031411DS)
Detroit Speed Rear Cradle Mounts (041510DS)
BMR Steering Rack Bushings (BK008)
BMR Differential Bushings (BK046)
BMR End Link Mounting Brace (ELK009)
However I can't find the Rear Z/28 Knuckles (23262765, 23262766). Not sure what I can use as a substitute.
I'd also like to know if I'm missing any Z/28 components from my list, or if they're any other upgrade I should do while I'm at it.
I'm running stock wheels (245/55/R18, squared) for now, but a lightweight set from Apex Wheels (19x10xET20, on 275/40/R19, squared) is in the near future.
Eventually I'd also like to do the various braces and connectors to stiffen up the chassis, but I think what I have so far will be a good start.
I think going with FE2 shocks and springs will balance out the stiffer Z/28 arms/bushing and bigger sway bars, resulting in a happy-medium street setup.
Any input or tips would be much appreciated.
Thanks,
Mat
Mat28 is offline   Reply With Quote
Old 03-01-2026, 04:54 PM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Those Z28 knuckles have been discontinued for a while. I'm surprised any of that stuff is still available. I don't think I would go with an FE2 shock and spring. I've heard Bilstein 1LE replacements are a good upgrade. I run Z28 and 1LE suspensions on my cars so I can speak what they ride like. There is actually not a lot of difference between the Z28 components and SS or 1LE that would affect ride. What makes the Z28 ride harsh is the shock/spring combo.
Old 03-01-2026, 09:25 PM   #3
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Upper rear control arm mounts. The SS/1LE/ZL1 have bushings that have voids where the Z28 bushing is solid.
Orange Krush II
Old 03-05-2026, 06:44 PM   #4
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
The only Z28 suspension component I have on my 2010 2LT is the rear Z28 LCA's. I have been running this setup for at least 9 years now.
OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 03-06-2026, 08:24 AM   #5
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Oh man she's looking great!! Stance is just right!
1JEWLDSSRS is online now   Reply With Quote
Old 03-06-2026, 03:22 PM   #6
SummitWhite11
Drives: 2010 2LT/RS
Thanks! This pic was taken about 8 years ago. The suspension components have about 15-20k miles on it and still holding up well as I don't drive it often nowadays as i would like.
2010 2LT/RS
Old 03-06-2026, 05:26 PM   #7
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Gotcha..
Old 03-07-2026, 04:46 AM   #8
Mat28
Yep, knuckles for any model aren't available anymore. I was able to find a replacement for the rubber bushing, and SPL said they're about to release replacement sphericals.
I was actually wrong, it turns out only the toe links are Z/28 specific. Everything else is ss/1le/zl1.
I'm going to take your advice and return the FE2 setup and get the Bilsteins. It seems the general concensus is they're great.
What springs should I pair them with? I've seen Hotchkins and BMR talked about alot. But I'd also be fine with OEM springs assuming I can find them.
Old 03-07-2026, 04:53 AM   #9
Mat28
Thanks.
Just ordered BMR's rear upper control arm bushing kit (BK039) and rear upper inner (BK017)
I ended up ordering aftermarket lower control arms, toe links, and trailing arms, so that should complete the rear end.
Old 03-07-2026, 05:01 AM   #10
Mat28
First, beautiful car my guy. Love the wheels.
Unfortunately, I was mistaken and apart from the toe links, everything was actually ss/1le/zl1.
I've since purchased Spohn LCA's with the delrin bushings.
How are the springs and shocks compared to OEM? I'm going to do Bilsteins in place of the FE2 setup.
Old 03-07-2026, 05:30 AM   #11
Mat28
For anyone following or wanting to use my part numbers as reference, except for the toe links, the other arms are just FE2 thru FE6 replacements.
I ended up purchasing:
Spohn Pro-Touring Rear Lower Control Arms w/Delrin Bushings (C10-221-DEL)
UMI Adjustable Rear Trailing Arms w/Roto-Joints (2526)
UMI Adjustable Rear Toe Links w/Roto-Joints (2524)
Gen 6 Radius Rods w/BMR Sepherical inserts
And added:
BMR Front Lower Control Arm Inner Bushings (BK018)
BMR Rear Upper Control Arm Delrin Bushings (BK039)
BMR Rear Upper Control Arm Inner Bushings (BK017)
I'm also doing the Bilstein B6 Performance shocks instead of the FE2 setup, but I'm yet to find a place that has all 4 in stock.
Anyone have spring recommendations? Not sure if I should go with an aftermarket lowering kit or an OEM variation.
Also I've seen quite a few chassis braces from BMR, Hotchkins, Ultra Racing, etc... What's are the best ones?
Old 03-07-2026, 07:07 PM   #12
SummitWhite11
Drives: 2010 2LT/RS
Thank you! At the time I placed my order 8-9 years ago... the Bilsteins were on back order to what felt like forever. I had waited 7-8 months patiently through a vendor in which I had to do a charge back through my CC company. So with that in mind I cannot say what the difference felt like. All I know is I am happy with my setup. I would have preferred the Bilsteins... as I ran them on my former 87 Corvette, 2015 Xterra and now 2025 Frontier. Bilsteins are great and you get your money's worth. Would I go that route when my Koni's finally need replacing... maybe... but the Koni's feel GREAT as is... it's your call.
2010 2LT/RS
Old 03-08-2026, 07:55 AM   #13
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
I have the Hotckis springs and I am happy with them, I also have the Hotckis Chassis brace and I Highly recommend it, I had it before I went with Solid cradle bushings which is another highly recommended mod by me. I believe that the Chassis brace will serve you just fine, I don't really need both but I had so I ran them.
I have a full BMR Suspension, I did have an issue getting my rear alignment spec exactly where i wanted it, A Adjustable rear LCA would have made it easier. I was able to get the spec but it took some modify.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 03-09-2026, 06:11 PM   #14
CamaroCracka
I run ZL1 springs on the vert with a 27/32 bar combo, so I can't really make recommendations based on experience. I can tell you your spring choice should work with your bar choice, i.e. not too much spring with big bars. The 1LEs ran a 27/28 combo with SS springs but realize most factory setups are designed with understeer to be more forgiving.
Here is a link to Justice Pete's The Book post. He has forgotten more about these cars than I will ever know.
https://www.camaro5.com/forums/showp...&postcount=485
2ls, suspension help, suspension mods, suspension setup help, z28 suspension
