![]() Drives: 14 SS Join Date: May 2019
WTB stock SS air filter housing
Just seeing if anyone is looking to offload a factory air box for a SS , MINE IS A 14 , but I believe they're the same 10-15
Thanks |
![]() ![]() Drives: 2014 1SS/1LE Join Date: Nov 2015
Pretty sure I have the original in my garage somewhere. Depending on where you are, shipping could be expensive because it's bulky.
Sent from my Pixel 8 Pro using Tapatalk
![]() Drives: 2014 camaro 2ss/rs Join Date: Oct 2020
I have one in Nebraska
Sorry , been super busy, how much , where you located ?
Thanks |
#6 |
pm sent
