Old 02-01-2010, 09:43 PM   #1
upstateny
Drives: 2012 ZL1
LT header and exhaust question
I apologize if I'm naive, but with the LT headers with high flow cats from ARH, is it still possible to get borla cat backs? Do the headers end where the stock headers normally would, to get the proper connection? Or is it even worth it - should I get the axle back instead (ie how's the stock pipe from cat to axle?)
thanks in advance for the advice
upstateny is offline   Reply With Quote
Old 02-01-2010, 10:29 PM   #2
TommyTSquared
TommyTSquared's Avatar
Drives: RSSS
You can mix and match brands. Some companies wont make a header, but make good exhaust systems from the cat back and vice versa. Lots of applications have a flange type connection, in which case it would be wise to make sure the exhaust pipe is the same size: 3", 2.5", etc. I believe stock, the pipe is 2.5" all the way around (please someone correct if this is incorrect). Headers will meet at the collector, then the cat, which will bolt up at the same place as the stock exhaust header/cat would.
In short, you can get ARH headers with cats, and still get a borla exhaust.
I'm by no means an exhaust expert, so someone feel free to correct me if need be.
TommyTSquared is offline   Reply With Quote
Old 02-02-2010, 09:49 AM   #3
upstateny
Drives: 2012 ZL1
great. thanks for the help, I figured the connections were in the same place, but before spending that cash, I wanted to double check.
Old 02-02-2010, 09:56 AM   #4
Camar0wn3d
formerly "wh0rsep0wer"
Camar0wn3d's Avatar
Drives: 2016 1SS Summit White
Be careful, though...there are two options when getting the ARH headers...you need to specify when ordering what you are planning to do, because the standard ARH come with an X-pipe, with extends beyond the connection for a cat-back and you would have to cut either the ARH pipe or the Cat-back.
However ARH does offer the option to just have the headers with the cats, and ends where a cat-back would begin...you just have to specify that this is the option you are looking for.
2010 1SS/RS - CGM/Gray Interior - M6 (SOLD) Kooks 1 7/8" headers, Solo Mach-X, Vararam.
2012 2LS - Black A6 (SOLD)
2016 1SS Summit White A8
Camar0wn3d is offline   Reply With Quote
Old 02-02-2010, 09:23 PM   #5
upstateny
Drives: 2012 ZL1
Thats exactly what I was looking for. I didn't know if the x-pipe on the ARH was in the same "anatomic" position as the Borla X-pipe. I really don't want to do any cutting.
RATING HEADERS??? SAUCE Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 20 12-02-2011 08:21 PM
LT Header Hiss (Exhaust leak sound) NinoSS Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 17 03-11-2010 07:41 AM
EXHAUST Milk 1027 Wiki 2 03-07-2010 09:20 PM
I Have a Question About The Stainless Works Exhaust System & Stock X-Pipe. RCPW Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 27 12-28-2009 01:43 PM
(UPDATED) Stainless Works exhaust and header systems!! (Tag's SS w/ HP #'s) Milk 1027 Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 162 07-09-2009 06:39 AM
