![]() Drives: 2011 Camaro ss Join Date: Jan 2020
Highway pull, just revved
2011 Camaro SS automatic. 415 stroker, blower, 3600 stall, 3.91 gears, Eaton tru trac.
Driving home today, when I hit the highway I wanted to do a little pull. I was probably doing around 50 mph in Drive and I stomped the gas and the car just revved up to 5000 rpms and I let off. I cruised for about 15 seconds and tried again and the same thing happened. I have an aftermarket trans dipstick and I will check the fluid tomorrow. If levels check out okay, what should I look into next? The car drives and shifts fine and never has done this before. |
![]() Drives: 2014 Camaro 2SS/RS Join Date: Dec 2025
Uneducated observation but I experienced this (and still kinda working it out) when I accidentally set the trans adapt preset and reset the fast adapt learn via hp tuners. I managed to get 1, 2 and 3rd gear to shift correctly via the former option and doing WOT pulls. I reckon it's something to do with torque management in the TCM in your case but like I said, it's a uneducated observation.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Sounds like you have overpowered the transmission, and the clutches are worn out causing the trans to slip.
#4 | |
Read through here, some great info... https://www.camaro5.com/forums/showt...t=37093&page=4
I'm pretty sure it usually flashes, grabs and goes and this time it just revved high. I was worried to stay into it. The car doesn't get driven much and usually does not get driven hard.
#6 |
Okay, it's definitely a flash. I just don't remember it taking "that long". I stayed in it, revved to 5000 and it engaged and took off.
#7 | |
