Old 03-30-2026, 02:42 AM   #1
Z28000
Z28000's Avatar
Drives: 2015 Chevy Z28
2015 Z28 exhausts smell
I love this car and everything about it but when I drive with my 7 year old that loves this car and everything about it hahah I’d like to figure out the way to keep exhaust smell out of it I feel like it’s coming in straight from trunk I know this track car and it came bare in some areas but any suggestions if how to seal or plug anything or would trunk insert or whatever it’s called would help
Just looking for suggestions I know it probably sounds ridicules
But thank you all in advance haha
2015 Z28 #572 BLACK NO AC
Z28000 is offline   Reply With Quote
Old 03-30-2026, 06:13 AM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
Have the cats been removed and have you checked the exhaust for leaks?
Sent from my Pixel 8 Pro using Tapatalk
Old 03-30-2026, 07:25 PM   #3
1970judge
Drives: 2015 Z/28, 2007 HHR
Its modded with a cam, meaning it was tuned. You'll probably want to start there.
1970judge is offline   Reply With Quote
Old 03-31-2026, 04:14 AM   #4
Z28000
Z28000's Avatar
No cats are still in place . I will check for exhausts leak. Thank you
Old 04-03-2026, 06:51 PM   #5
void_kp
void_kp's Avatar
Drives: Chevrolet Camaro Z28 (2015)
this.
make sure the air/fuel mixture across all rpm and loads is correct. In other words, bring it to a GOOD tuner and have him/her to check and correct the map
2015 Red Z/28.
Seattle area
void_kp is offline   Reply With Quote
Old 04-25-2026, 09:10 PM   #6
FLOW TIE
FLOW TIE's Avatar
Drives: 2015 Z/28 #898
My 12 year old Z doesn’t put out any nasty fumes. Bone stock.
I bet you’ve got a modded car. Maybe Cat delete ??
FLOW TIE is offline   Reply With Quote
