![]() Drives: 2012 SS Join Date: Feb 2016
Caliper bolts
Quick question, are brake caliper bolts on SS one time use only? Thanks
2012 2SS/RS 6speed, Howards asa cam on 113lsa Stainless works LT's, NPP exhaust, Z28 Cai, 3.91 gears. Tuned by Blue Thunder 2 racing Lubbock Texas.
It don’t come easy.
There are TTY (torque to yield) and they are considered one time bolts but, there are those who will reuse them.
![]() Drives: 2013 Chevrolet Camaro ZL1 Join Date: Jun 2015
Yes they are
133 lb-ft of torque |
Tri-County Camaro SWFL
As stated they are a TTY bolt. Theyre torqued to a value which and then plus a degree. I think its 30ft/lbs plus 90 degrees. The bolt stretches so its designed to be a one time use. Theres many many people who reuse them without any issues.
New bolts also have a dry locktite on them
Thanks!
#6 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
After several uses, they get more difficult to remove and install. Screaming Chicken has non-TTY bolts if you are looking to replace them. I have done a lot of brake work and only recently replaced the factory bolts with Screaming Chicken units. The vert still has factory bolts.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
#7 |
![]() Drives: 2012 camaro ss Join Date: Sep 2018
I reused mine with a little loctite ,no issues at all!
GPI Powered
#8 |
Same here, reused mine..
