Old 02-06-2010, 11:06 AM   #1
NapalmSound
NapalmSound's Avatar
Drives: 2010 LS CGM
Exclamation Water in the doors.
What's up C5? this my my first thread(been lurking around for a little bit), but I noticed something that concerned me about the windows and doors. i went through a touchless car wash the other day and when i was done drove to my girlfriends house. by the time I got there the car was completely dry, I dont remember why but i put the windows down, and when I put them back up they were all wet. My question is would the moisture in the interior of the doors cause any damage or rust from the inside eventually??
thanks
NapalmSound is offline   Reply With Quote
Old 02-06-2010, 11:19 AM   #2
Number 3
Hail to the King baby!
Number 3's Avatar
First the water was probably only from the seals. They will stay wet a little longer because as you drive the are not getting "air dried".
But the inside of your door, any door, not just your Camaro is condidered a wet environment. With a window that is designed to go up and down, it is nearly impossible for to keep the water out completely.
If you were to pull the trim panel off of the inside of your door, you would see that it is completely sealed off.
So water can get in the door, but should not get in your car.
To prove this, look under you door. Do you see the slots in the bottom along the hem? Those are intended to drain the water that does mangage to get in.
So water in your door is nothing to worry about...................unless it isn't able to drain out because the drain holes get blocked or damaged.
Hope that helps
Old 02-06-2010, 12:09 PM   #3
NapalmSound
Drives: 2010 LS CGM
That actually helps a lot. Thanks.
Old 02-06-2010, 04:30 PM   #4
2ndgenz28
Thread Killer
2ndgenz28's Avatar
Drives: All Black
Send a message via ICQ to 2ndgenz28 Send a message via AIM to 2ndgenz28 Send a message via Yahoo to 2ndgenz28
Water, snow n ice will get into the doors, unless you made it so the windows never went down and caulked them shut
Just if your conserned, every 3-5 years get an inspection and recoating of rust proofer, in the door, under body and such....
2ndgenz28 is offline   Reply With Quote
Old 02-06-2010, 06:58 PM   #5
Easy Go
Easy Go's Avatar
Drives: LLT MV5 B34 N65... period.
There is a large waxpaper-like barrier inside the door which protects the components from water.
In the early morning... when there's only a mere suggestion that the sun is going to bother coming up at all that day - a CGM blur accompanied by the anthem of 312 horses awakens the morning commuters from their NPR-induced stupor. Charging past the front lines in an all-or-nothing battle cry that the King has returned...
Easy Go is offline   Reply With Quote
Old 02-06-2010, 07:08 PM   #6
markbolt
Drives: 2010 2SS Camaro
thanks
That is with any car, the seals aroudn the window take a little longer to dry
markbolt is offline   Reply With Quote
Old 02-06-2010, 07:12 PM   #7
IROCanSS
Drives: 89 IROC 350
Correct, and this really gets under my skin... beautiful summer day, jsut spent all day cleaning your ride and now you want to go cruise so you put down the windows... At the end of the night when you put your windows up... they look like CRAP!
What song are you listening to right now Muscle Master Off-topic Discussions 6760 11-08-2025 02:54 AM
Washing/Detailing for Newbies MRK III Z28 Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 124 02-05-2024 10:55 PM
Water spots on plastic SirZoltan Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 6 11-20-2009 09:23 PM
How to dry your Black Camaro without water spots gzartman Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 55 10-27-2009 04:46 AM
Water Spots-Help Dr Jkel Cosmetic Maintenance: Washing, Waxing, Detailing, Bodywork, Protection 16 07-17-2009 07:49 PM
